603,800 active members*
3,113 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Need Lathe assistance ASAP please
Results 1 to 12 of 12
    Dec 2010
    Alright, I am programming a Nakamoura Mill turn. I am programming a turbine pump and shroud in Mastercam. So basically the shroud fits inside turbine blades. It looks very similar to this
    So only focus on the far left on the part. The blades on my part look similar but they are only x,z blades there is no contouring on the blade. now imagine a shroud that fits perfectly inside the blades. The contour of the blades SHOULD match the contour of the shroud perfectly.
    There is a good size gap between the blades and the shroud when I try to match them up. This is where I think I made my mistake. I didn't use cutter comp at all in mastercam. I turned it completely off in mastercam and on my control I had my cutter geometry set to 0 for both height and diameter. I basically programmed it as if I were programming from a tool point. I believe this may have really messed up my contours. It looks like any where between .1 and .03 gap on a part that I have a mating tolerance of .005. Please help me out. Is my issue that I didn't use cutter comp? If so how do I set it up in mastercam lathe? Thanks!
    Dec 2010
    btw this is x5 and the nakamoura is a fanuc control.
    Dec 2010
    So what I did was program a part to the dimensions on the sheet and did not use TNR compensation. Should I set it to wear or in computer? The diameters appear correct but the actual contour isn't mathing up.
    Oct 2011
    Edit, i just noticed this is for lathe.
    Yes, wear or computer will work fine for a turning tool, you need to use comp or the radiuses get messed up, as do tapers.
    Make sure in your control to set the value of the tool nose radius. Make sure the insert youve selected on your tool in mastercam is the proper radius that youre going to actually cut with.
    Dec 2010
    I see in mastercam where to input my tool nose radius buy why do I need to add it in the fanuc control? and if so where is this done? I am guessing on the tool data screen so I will figure that out. If however I do comp in computer and the tool path is adjusted accordingly, why would I need anything in the control. I should just be able to leave the tool radius a 0 in the control? Thanks for the help so far!
    Dec 2010
    bump
    Oct 2011
    Yes you would inout it on the tool geometry page, there is a column for nose radius.
    Reason for this is because thr tool is touched off in x and z, this is actually a theoretical point that is actually not on the tool surface at all. It will cut diameters and faces at the right points, but tapers and radiuses contact the tool differently, therfore thr tool must be compensated to keep it in touch wih the right point of the tool.
    Basically the proper contact point is dynamically changing as the tool moves around the radius, so the control needs to know where exactly the actual cutting edge is to cut it properly.
    Dec 2010
    Okay so input the tnr on the nc at the machine and inside mastercam when setting up tool parameters. Do I do cutter comp in computer or control or do I use wear?
    Apr 2005
    53
    I always thought if mastercam knows which insert you are using (in the edit tool), and you use wear as comp, then mastercam compensates for the radius. So I don't think you need to put anything in the tnr offset, if you use wear in mastercam.
    Dec 2010
    Quote Originally Posted by utengineer04 View Post
    I am pretty sure that is correct and that is what I did wrong. I am testing to today to verify. I will let you know how it plays out!
    Dec 2010
    Everything came out in tolerance after the changes! Thanks a lot guys.
    Jul 2003
    263
    from my lathe programming days, i always programmed to control comp with zero tool nose radius. the set up guy inserts the TNR in the machine control. this way the machinist is not tied down to one sized radius and has more control at the machine end. this way G41 & G42 are still being generated.
    If you can ENVISION it I can make it
  1. Quote needed asap on production cnc lathe/mill work
    By billet works in forum Employment Opportunity
    Last Post: 09-01-2014, 12:09 AM
  2. looking for assistance near philly
    By E2l2 in forum Mentors & Apprentice Locator
    Last Post: 02-14-2012, 03:31 AM
  3. Need assistance
    By Hari Kristianto in forum Engraving Machines
    Last Post: 03-01-2011, 05:15 AM
  4. Need some assistance
    By cpworkshop in forum Mentors & Apprentice Locator
    Last Post: 06-13-2008, 04:48 AM
  5. Assistance Please!
    By LMRecruiter in forum Employment Opportunity
    Last Post: 10-06-2006, 02:38 AM
