I have a Hurco KM1 mill and one of the servo boards is bad.
I have pulled it apart and started checking the drive transistors,
diodes....
But it would help loads if I had some reference material.
Sometimes I would get a OT/RMS error light on power up,
other times I would get other lights. and the OT/RMS would
stay cleared.
Unfortunately the other 2 axis are Westamp drives so I have
nothing to compare voltages/signals to.
All of the driver diodes/transistors seem to measure the same values
510-530 ohms one direction and 0 in the other for the diodes,
and 450-460 from case to either pin in one direction and 0 in the other
22-28 ohms between the pins either direction on the transistors.
FYI, I removed these components to check their values.
I have swapped the SD with the Westamp drives and the Westamp
still worked and the SD drive did not. So I have pretty much eliminated
everything but the SD drive. I am decent with board level work but I need
a reference board to compare to or a tech manual for this board.
Any help would be appreciated.
Curtis
