603,930 active members*
4,034 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Need Sample Waterjet / Plasma G Code Program
    Jun 2003
    205
    Hello all .. I would really appreciate it if someone could pass along a sample G code program for a part being machined with a waterjet or plasma. I can read the code, I'm just looking for formatting and such.
    It would be great if you could just make a text file ... maybe put a note next to the M code telling what it controls ... like :
    M42 (turns jet on)
    If you can email the file as an attachment ... I would really appreciate it. You can email it to [email protected]
    Also a question : Do most waterjet or plasmas have a controllable Z axis ... or is the Z axis manually moved ... the cutting started ... etc.
    I know this is asking for some time ... but I know their must be a good soul out there.
    Thanks in advance.
    Kenney
    Nov 2004
    71
    This is one for MY machine. Each control software may use different commands.
    G00 Rapid Move
    G01 Feedrate Linear Move
    G02,03 Feedrate Arc
    G04 Pause (I have a torch)
    M07 Torch Oxy On (Coolant A is what I use)
    M09 Torch Off (Coolant Off)
    M02 End
    I use TurboCNC to run my machine.
    G00 X 1.5000 Y 1.0000
    G04 P7
    M07
    G04 P.25
    G01 X 0.9420 Y 0.8677 F30.00
    G03 X 1.2106 Y 0.6250 I 0.2686 J 0.0273
    G01 X 2.6527 Y 0.6250
    G03 X 2.9213 Y 0.8677 I 0.0000 J 0.2700
    G01 X 3.1991 Y 3.6040
    G03 X 3.0571 Y 3.8698 I-0.2686 J 0.0273
    G03 X 0.8062 Y 3.8698 I-1.1254 J-2.1198
    G03 X 0.6642 Y 3.6040 I 0.1266 J-0.2385
    M09
    G00 X 2.0000 Y 2.0000
    G00 X-0.5000 Y 2.0000
    G00 X-0.5000 Y-0.5000
    G04 P7
    M07
    G04 P.25
    G01 X 0.1387 Y 0.0000
    G01 X 1.3590 Y 0.0000
    G01 X 1.3590 Y 0.1000
    G01 X 2.5043 Y 0.1000
    G01 X 2.5043 Y 0.0000
    G01 X 3.7247 Y 0.0000
    G01 X 3.7247 Y 0.5750
    G01 X 3.6247 Y 0.5750
    G01 X 3.6247 Y 1.6250
    G01 X 3.7247 Y 1.6250
    G01 X 3.7247 Y 2.6366
    G01 X 3.8338 Y 3.6680
    G03 X 3.7716 Y 3.8273 I-0.1865 J 0.0189
    G03 X 0.0611 Y 3.7998 I-1.8399 J-2.0773
    G03 X 0.0010 Y 3.6424 I 0.1264 J-0.1385
    G01 X 0.1387 Y 2.2860
    G01 X 0.1387 Y 1.6250
    G01 X 0.2387 Y 1.6250
    G01 X 0.2387 Y 0.5750
    G01 X 0.1387 Y 0.5750
    M09
    G92 X-4.7500
    G04 P7
    M07
    G04 P.25
    G01 X 0.0000 Y 0.1000
    G01 X 1.145335 Y 0.1000
    G01 X1.145335 Y 0.0000
    G01 X 2.365665 Y 0.0000
    G01 X 2.365665 Y 0.1000
    G01 X 3.5860 Y 0.1000
    G01 X 3.5860 Y 1.0250
    G01 X 3.4860 Y 1.0250
    G01 X 3.4860 Y 1.9750
    G01 X 3.5860 Y 1.9750
    G01 X 3.5860 Y 3.0500
    G01 X 0.0000 Y 3.0500
    G01 X 0.0000 Y 1.9750
    G01 X 0.1000 Y 1.9750
    G01 X 0.1000 Y 1.0250
    G01 X 0.0000 Y 1.0250
    M09
    G92 X-5.0000
    G04 P7
    M07
    G04 P.25
    G01 X 0.1000 Y 0.1000
    G01 X 0.5000 Y 0.1000
    G01 X 0.5000 Y 0.0000
    G01 X 1.6500 Y 0.0000
    G01 X 1.6500 Y 0.1000
    G01 X 2.1250 Y 0.1000
    G01 X 0.1000 Y 2.0500
    G01 X 0.0000 Y 2.0500
    G01 X 0.0000 Y 0.9750
    G01 X 0.1000 Y 0.9750
    M09
    G92 Y-3.0000
    G04 P7
    M07
    G04 P.25
    M09
    G92 X 8.2500 Y 2.0000
    M02
    Should look something like this
    Good luck, MIKE
    Jun 2003
    205
    I knew there was a good soul out there ... thanks a million Mike.
