603,400 active members*
2,668 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Need some direction-Problem solving new user
    May 2018
    Aloha everyone,
    Running Smartshop II with Vcarve Pro9 software. Fully self taught over the last few months. Problem: processor does not seem to adjust for material thickness. The Material (Z) is correct in Vcarve, z Zero set to top, material thickness is 39.83 mm. Adjusted on the spoil board top the tool lengths. Cut profile is 3/8" depth but the bit dives into the block.
    How should my troubleshot/problem flow work? Help from Laguna is practically non-existent and the manual is a joke. If my tool length is correct and my spoil thickness is correct, where do I go?
    May 2018
    Re: Need some direction-Problem solving new user
    UPDATE - i just adjusted one of my tools to the top of the new material and it cut fine. So I have to measure my tools every time I change my material thickness? If / then will changing my Z Zero to the bottom then allow the post processor to adjust for the material thickness?
  1. Igaging scales, solving the time out problem
    By Dano523 in forum Benchtop Machines
    Last Post: 06-23-2012, 05:09 AM
  2. Coolant Problem Solving
    By coolantman in forum MetalWork Discussion
    Last Post: 02-06-2009, 12:36 AM
  3. Help solving a motor problem???
    By barmybovine in forum CNC Machine Related Electronics
    Last Post: 04-06-2006, 01:53 AM
  4. Problem solving forum?
    By lsfoils in forum Community Club House
    Last Post: 10-05-2003, 07:49 PM
