587,418 active members*
3,752 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Need some FEA of HEB beams for a mechmate like router
Page 6 of 6 456
Results 101 to 120 of 120
  1. #101
    Oct 2010
    Quote Originally Posted by cnc2 View Post
    Remember, the longer the belt, the wider it has to be in order to keep stretch at a desired value.
    Remember, at 42.5 Kgf the stretch is 0.4mm/m (every meter of belt will stretch by 0.4mm) so a 3 meter long belt will stretch (0.4 x 3)=1.2mm, two 25mm 3 meter long belts will stretch 0.6mm at 42.5 Kgf, if you want to achieve 0.3mm stretch at 42.5 Kgf it will take two 50mm wide belts
    OK, it's doable, we can even hope attaining 0.15mm stretch if we use a 75mm belt, BUT, is it worth the money ? How much will it cost ? what speed (IPM) & depth of cut can we expect @42.5 Kgf of belt load ? (because if we overpass this load the error will be greater & unpredictable during machining)
    I'm not sure about the stretch value of 4mm/m is it for a 10mm wide belt ? then it'll be lower on a 25mm belt.
    cnc2.
    Hi, I think the highest forces are going to be a result of when the gantry direction reverses, which is consistent with some figures in the belt catalogs. This is an accelleration effect vs a velocity effect. I guess this means I need to go back and figure out what accelleration I will most like have.
    Thank you for bringing up this stretch challenge, as the effort to do the calculations is very worth while.
    _____________________
    watch movies online
  2. #102
    Apr 2007
    1955
    I took a look at mcmaster.com for fun and looked at their ball screw specs. While I am sure there are better ball screws out there, it was interesting to see that they spec them as having an accuracy of 0.3 mm per meter. (the spec used inches, but that is the converted number).
    This is an indication that the belts are not all that bad compared to off the shelf ball screws. Of course, the ball screw will have extremely high holding force compared to a linear belt, just due the nature of a thread, but even under the design loads listed here, it looks viable.
    It sure would be nice if someone were to run these numbers independently and see if my calculations are more or less right.
  3. #103
    Apr 2007
    1955
    Thanks to FandZ for pointing out that if I use counter weights, I need to figure these into the calculations.
    My idea is to use a counter weight on the shaft at the top of the belt, so 10 Kg on that shaft. This does not add to the stress on the belt, but does add to the mass undergoing accel.
    For 10 Kg of Z section movement, then:
    10 Kg x 9.8 m / s / s = approx 100 N from accel of the counter weight.
    If the mass of the moving section were to double to 20 Kg, and we continue to assume 1 G accel settings, then:
    - 20 Kg held vertically, so roughly 200 N from mass.
    - Holding force of 400 N
    - Accel of moving Z section = 20 Kg x 10 m/ s/s for 1 G = another 200 N
    - Accel of Z counter weights = 200 N
    Total force = approx 1,000 Newtons peak
    Starting to get into some serious forces. Similar to a 250 Lb man jumping up and down on something and hoping it deflects less than +/- 0.003 inch.
    Now I need to do some motor calculations, but I am pretty sure my current motors are not even close to this power level.
    CNC2 - is any of this helping or making your life more complicated ?
  4. #104
    Feb 2008
    553
    Thanks harryn, it's always good as it can inspire new ideas.
    +-1mm should be acceptable, OK I wanted to reach +-0.1mm/3meters (without including spindle run out...etc) at least for the no load positioning (like for a plasma cutter) but the belt has +-0.8mm/m & that's what scared me.
    I'm aiming a moving gantry design like the mechmate, OK +-3mm/3meters is acceptable for wood cutting, but it'd be interesting to see the result when engraving (backlash on a lead screw almost ruined one of Irfan's engraving jobs).
    For the linear encoders: I always thought they were expensive, but recently, I had an idea on how to make a cheap linear encoder, well you take a $20 encoder (AMT102) mount it on the shaft of the smallest pulley available & let it run on an unloaded belt (one narrow tracking belt per axis) that can be made out of one of the most accurate affordable belts available.
    I have no idea of the kind of accuracy we could reach with such a setup, & don't know how we could use it with the CAM software.
    Any ideas ?
    Thanks !
    cnc2.
  5. #105
    Apr 2007
    1955
    Hi, I am not sure of this, but I think that Mach III cnc control software has a way to input "corrections". Please double check this, but I think that you can take multiple very accurate position measurements along an axis and input these into Mach. The software then uses this as a sort of a correction table for that axis. Obviously, this is not that helpful for backlash, but as far as absolute positioning, it is very helpful.
    It is possible that I am confusing this with other software, so a check through the manual or the mach forum might be in order.
    Of course, this all assumes that you can actually make these very accurate measurements on your router.
    I suppose one of the most accurate methods would be a laser interference based meter, which counts wavelengths (650nm) but I don't have easy access to this. Maybe your university does
    BTW - the ATL belt is more accurate than that I think.
  6. #106
    Feb 2008
    553
    There is no way to use Mach3 with linear encoders in a closed loop look at post #2 from H.O in this link:
    http://www.cnczone.com/forums/diy-cn...ar_scales.html
    Linear encoders can be used with Mach3 only for display purpose without correcting the movement's accuracy.
    It might be possible in EMC2 Linux.
    Thanks !
    cnc2.
    EDIT:
    Forget about the laser meters unless you wanna sell the house to afford the down payment
    A 20mm O.D pulley connected to a 1024 CPT(count per turn) encoder, running on an unloaded belt (Zero stretch) can give a theoretical accuracy of +-0.06mm (one encoder count=0.06mm of linear movement)
    20 x Pi=62.83 (linear travel of one turn of the pulley)
    If one turn of the encoder=1024 we end up with 62.83/1024=0.061mm of travel per encoder count (theoretical dream) if the real accuracy is ten times lower(worse) on a three meter distance we'll end up with 0.06 x 10= +-0.6mm
    Better results can be achieved with a smaller pulley and/or a higher resolution encoder.
    The real question is: Which CAM software works in closed loop to make this possible ?
    Well, I think it's doable with EMC2, read this: http://wiki.linuxcnc.org/cgi-bin/emc...es_On_One_Axis
  7. #107
    Feb 2008
    553
    UP
  8. #108
    May 2006
    122
    Any ideas ?
    Thanks !
    cnc2.
    If you've determined that rack and pinion drives and a tube steel gantry is the optimum solution, I don't understand why you want a "mechmate-like" design and not just build a mechmate.
    A mechmate with a spindle and timing belt driven steppers is eminently capable of moderate aluminum milling.
    EMC (and Mach III also, I understand) will allow you to fine tune the effective steps/inch as accurately as you want to be. In other words, it doesn't matter if the racks are 10 tpi or 10.2 tpi. You'll input your calibrated value when you do your final testing.
  9. #109
    Feb 2008
    553
    Quote Originally Posted by lumberjack_jeff View Post
    Well, I'm not so sure about the local availability of rack & pinion, and I don't like Mechmate's rail system with V grooved wheels...etc.
    OK, but I never saw belt driven steppers...Motors are usually used to be driving not driven
    I already know that, but I thought that a linear encoder could be the right solution to compensate the belt stretching & have a reliable machine that will get the job done, not a machine which won't keep track of the real position of the cutter & end up with misaligned cuts because the belts have stretched & have do redo the job at a lower speed to reduce stretching effects.
    Thanks !
    cnc2.
  10. #110
    Apr 2007
    1955
    Hi, of course it would be perfect if there was a way to use linear encoders close looped back to the control software. (EMC or Mach III)
    So far, what I have found is that with servos, you can use the servo controller to run closed loop with rotary encoders, but this is not fed back to the controller software. (mach / emc) I am still a beginner, but that seems to be similar to how a standard stepper motor already works, although potentially more precisely.
    Either way, feedback from the rotary position doesn't really solve the "where is the router really at" , as all kinds of things (pulleys being not perfectly concentric, belt stretch, etc) can affect the actual linear position.
    I looked at both EMC and Mach III for their ability to run in a closed loop mode from linear encoders. (not rotary encoders). I have confirmed that Mach III cannot do this, and so far, it does not look like EMC can either, or at least that is what several similar questions have been answered indicate.
    Not to be beaten, there is a way to pre-calibrate the linear position using the control software. If you can make position measurements precisely enough, and feed this back into the software during a calibration.
    I did see some linear encoders that use a "tape" that rolls out straight for the encoder portion. If a person were sufficiently clever, they could figure out how to use an encoder signal to count out where things are and input this info into Mach. I am not ready for that level yet, so instead I am considering another method to get these measurements.
    My brother has a decent quality manual mill, which can pretty accurately position to +/- 0.01mm / meter, if he goes only in one direction, (to avoid any backlash). We are in discussion of how to use it to make a very accurate ruler suitable for the task. The trick, is that I need it to measure nearly 3 meters, and he can only make items about 1/2 meter long, so some assembly may be required.
  11. #111
    Feb 2008
    553
    Quote Originally Posted by harryn View Post
    If you lock the shaft of a stepper motor, its controller still thinks the motor did rotate (try to stop a stepper driven print head in an epson printer).... on the other hand, with a servo motor the controller "sees" through the encoder, how much the motor rotates & compensate the errors, in real time !
    Exactly !
    I think that I posted a link a few posts earlier about how to configure EMC2 for closed loop with linear encoders, it's not a clickable option, it has to be set in a configuration text file.
    Sure, but it's only perfect for lead screws which do not stretch. With belts, the stretch is almost unpredictable because when you build your machine you say, OK this belt will stretch 1mm under 45 Kgf load...BUT, if during a job, the load on the belt goes past 45 Kgf, then, the stretch will be greater than 1mm, & you can't predict how much greater because you can't predict the load
    Don't go designing/engineering new components, you don't have the knowledge/tools/labs/budget, use what's already available.
    I've read somewhere that 20 or 25mm square key stock bars had +-0.01mm tolerances, if you get a 3 meters long bar & tension it, it shoud be strait.
    Hope it helps !
    cnc2.
  12. #112
    Jun 2003
    2103
    cnc2.
    Now those are two comments I can help you with. I have a very old Digital Tool 5X10 router that of all things, has rack and pinion, v groove wheels, and belt driven steppers! I have use this machine since 1991 and now almost 20 yrs later, I can drill a hole on the table, make any moves I want to make up to almost 400ipm, go back to that hole position, redrill it and not fuzz the wood! What more would you want? Maintainence on all three mentioned systems is nil.....other than when you carve huge amounts of foam or cut a lot of mdf, then you have to clean the rack every once in a while!
    BTW there is a soon to be 6 axis controller that will do dual loop feedback with position correction, assuming you can afford the long encoders (I can't), or it can do quasi position control via known force needed for each axis. It will be, or supposed to be open source soon. Do a search for the CNCBRAIN here on the Zone.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
  13. #113
    Feb 2008
    553
    Quote Originally Posted by turmite View Post
    To me this means that it is the belt which drives the stepper motor & it sounds weird because in fact it is the motor which actually drives the belt....am I wrong ? (English is not my native language so, explain please)
    Thanks for the input ! that sounds interesting for an accuracy/repeatability, I shouldn't need more that that OK but is your machine belt driven or does it use rack & pinions with belt reduction on the steppers ? Any pics/vids ?
    Mike
    Thanks for the info on CNCBRAIN, looking at the electronics hardware it uses, it won't be a DIY project, most of us will need to buy it ready for use, since the assembly/soldering of the used components require skills & tools unavailable to the average DIY builder. Will cnc brain be affordable to us ?
    Same here, I can't afford linear scales(long encoders), but I thought about replacing them by a cheap rotary encoder connected to a toothed pulley which rolls on a fixed toothed belt just for tracking purpose, if the belt is accurate, then, if the circumference of the pulley is around 6cm, a resolution of 60/256=~0.2mm can be reached with a 256 CPR encoder (each turn of the pulley (60mm) will be divided into 256 steps or more with a higher resolution encoder)
    Thanks !
    cnc2.
  14. #114
    Jun 2003
    2103
    To me this means that it is the belt which drives the stepper motor & it sounds weird because in fact it is the motor which actually drives the belt....am I wrong ? (English is not my native language so, explain please)My apologies to you. I guess I did say that wrong. The steppers are using belts to drive the machine through a transmission that also uses belts and gears.
    Thanks for the input ! that sounds interesting for an accuracy/repeatability, I shouldn't need more that that OK but is your machine belt driven or does it use rack & pinions with belt reduction on the steppers ? Any pics/vids ?My machine uses rack and pinion but the belt driven transmission with stepper is what gives the motion
    Thanks for the info on CNCBRAIN, looking at the electronics hardware it uses, it won't be a DIY project, most of us will need to buy it ready for use, since the assembly/soldering of the used components require skills & tools unavailable to the average DIY builder. Will cnc brain be affordable to us ?The Brain is suppose to be ready to hook up and run once you get it, and the cost is projected to be around $500 US
    Same here, I can't afford linear scales(long encoders), but I thought about replacing them by a cheap rotary encoder connected to a toothed pulley which rolls on a fixed toothed belt just for tracking purpose, if the belt is accurate, then, if the circumference of the pulley is around 6cm, a resolution of 60/256=~0.2mm can be reached with a 256 CPR encoder (each turn of the pulley (60mm) will be divided into 256 steps or more with a higher resolution encoder) I am going to try the strain/force feedback first to find out if it does work, and if so, I will then set up a very accurate index point for the machine to have for reference. If these do not work to my satisfaction, I intend to build my own long encoders using magnetic feedback
    Thanks !
    cnc2.
    I hope some of this helps you. Good luck with your build.
    Mike
  15. #115
    May 2006
    122
    Native english speakers like me often take liberties with the language. I phrased the original poorly. Yes, what I meant is a rack and pinion machine with the stepper driving the pinion via a timing belt drive.
    I've seen shopbot/mechmate machines (v-wheel rails, rack and pinion drives) cut everything except steel.
    MechMate CNC Router Forum
    Thanks !
    cnc2.
    EMC can use the input of rotary encoders to terminate a program in event of following error (missed steps)
    http://wiki.linuxcnc.org/cgi-bin/emc..._With_Encoders
  16. #116
    Feb 2008
    553
    Mike
    Yes, it helps, thank you.
    I hoped your machine would use belts instead of racks.
    Do you have more info on these magnetic encoders ? will it be EMI proof, to avoid false feed back perturbations...any idea about the cost & difficulty of this project ?
    cnc2.
  17. #117
    Feb 2008
    553
    EMC Documentation Wiki: Steppers With Encoders
    Thanks for the links !
    Well, rack & pinion ain't my cup of tea because of the local unavailability...etc. Did anyone of you ever see a fully belt driven machine in real life ? how does it perform ?
    The link you posted about EMC, is for following the motor's position not the axis position. (would axis's be correct ?) in case of belt stretching it would be useless. Btw, I'll be using UHU servo drivers & servo motors.
    Thanks !
    cnc2.
  18. #118
    Jun 2003
    2103
    http://www.cnczone.com/forums/linear...so_myself.html
    If you have not read this thread, you need to. I want to use this system on my next machine but am not sure if it is strong enough to work considering the weight the gantry will be carrying.
    As to the magnetic encoders......I do not have all the details yet, but the ones I have were given to me by a certifable(sp) genius!
    Mike
  19. #119
    Feb 2008
    553
    Yea, I've already been through that thread & what bothers me is that the system was made by Mike Everman. This guy is known for his high design/fabrication skills, on an other thread he threaded the interior of a ball bearing to make a sort of ball/roller screw for cheap.
    I'm afraid this belt system will require a fair amount of fabrication accuracy, beyond our capability.
    This system doubles the belt without doubling the width, but if some slipping occurs between the two belts, the system's load rating will suddenly drop down by 50% (like using only one of the two belts).
    Well, Mike Everman can afford to dance on the edge of technical "doability" & he's respected because of this.
    If you dare the challenge then, good luck ! & keep us posted
    cnc2.
  20. #120
    Apr 2007
    1955
    Mike
    Hi Mike, I have considered V groove wheels, but have been unsure how to properly size them. Can you give us some insight into the size / brand or other selection info on these V groove wheels ?
    HarryN
Page 6 of 6 456
  1. Introducing the "full-size" MechMate router
    By Gerald_D in forum DIY CNC Router Table Machines
    Last Post: 05-27-2013, 05:42 PM
  2. EZ-Router to MechMate Comparison
    By dmoore in forum DIY CNC Router Table Machines
    Last Post: 05-29-2011, 09:37 PM
  3. how can I combine two beams ???
    By cosmo2 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-19-2009, 11:34 AM
  4. 2 or more CO2 Laser beams combining?
    By Konstantin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-21-2009, 07:08 PM
  5. How to combine two CO2 laser beams?
    By jlew in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-19-2007, 01:29 AM
