586,058 active members*
3,419 visitors online*
Results 1 to 11 of 11
    Nov 2017
    591
    Need some help getting started on a few macros
    I built a mill turn setup similar to simpson36's "inturn" or the tormach rapid turn (except mine is servo driven for index milling) and I need a few macros to get everything working the way I want. I already have the swap axis stuff figured out, now I need a few other things to handle the gang tooling offsets and coolant nozzles. Both follow similar logic so let's start with the coolant macro.
    Basically I want 8 individual coolant nozzles that are chosen based on tool number. I'll write out how it needs to happen and hopefully you guys can help me convert that to proper vb language
    Get selected tool
    If tool number < 100, activate signal output 1
    Else
    If tool number = 100, activate signal output 2
    Else
    If tool number = 101, activate signal output 3
    Else
    Etc, up to 8 outputs. The reason I have tools 1-99 grouped into 1 output is because those will be used in main milling spindle and all use the same nozzle. The rest will have their own specific location on the gang plate and need their own nozzle, however I may want to also use small groups of possible tools for a specific gang location. For example I might want something like:
    if tool number > 104 and < 111, activate signal output 3
    or something like that. As far as I know, mach3 won't allow me to modify m7, but it's easy enough to go into my post processor and assign a new m code for coolant. I'll also need a code to turn off all coolant outputs. I assume it will just look like this?
    Deactivate output signal 1
    Deactivate output signal 2
    Deactivate output signal 3
    Etc up to 8
    I'll also need to have this happen in the m30
    My tool change macro will have similar logic, but instead of activating signals, it will apply work offsets for specific tools or tool groups. I could use g52 offsets instead so the work offset can be moved around and have g52 tool offsets follow, but decided to go with work offsets instead since my zero position will always be the nose of the mill turn spindle and it will be easier to set up and make adjustments to tools. If I used g52, I would have to go into the macro to make ajustments.
    Any help is greatly appreciated. I think once I see a few examples of how to write out these if then else statements, like the ones I listed above, i should be able to get going on these.
    Nov 2017
    591
    Re: Need some help getting started on a few macros
    figured it out. heres my coolant macro,
    tool = GetCurrentTool
    If tool < 100 Then
    ActivateSignal(Output4)
    End If
    If tool > 99 And tool < 106 Then
    ActivateSignal(Output5)
    End If
    If tool > 105 And tool < 111 Then
    ActivateSignal(Output6)
    End If
    This is just part of it and uses one nozzle for tools 1-99, another nozzle for tools 100-105, and another nozzle for tools 105-110. I tried using "else if" for each condition instead of separate if then statements for each, but if didnt like it for some reason and was giving an error on the "if" of else if for some reason. guess it doesnt really matter, this is working. I also got my tool based work offsets working as well. Same format but instead of activate signal, i just use code g54, g55, g56, etc.
    Apr 2005
    304
    Evaluation of your macro gives the folloving:
    Output 4: Tools 0 to 99
    Output 5: Tools 100 to 105
    Output 6: Tools 106 to 110
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Nov 2017
    591
    Quote Originally Posted by ZASto View Post
    Ah yes, correct
    Nov 2017
    591
    This was the other way I tried to write it but was getting syntax error:
    If tool < 100 Then
    Else If tool > 99 And tool < 106 Then
    Else If tool > 105 And tool < 111 Then
    End If
    Error shows up on the "if" of else if, but when writing it, it highlights blue like it recognizes it. What is wrong here? It works fine written the other way with individual if then's, I'm just curious so I know for the future.
    Mar 2003
    35538
    Try ElseIf, with no space.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2012
    145
    Wouldn’t it be easier to have one coolant but adjust the angle like the Haas programable ones?
    Nov 2017
    591
    Yep. That was it. That was actually the first way I tried it and it didn't work, but then I remembered I also made the mistake of not adding if end, so that was the actual reason elseif wasn't working originally. I think I'll also try case select to see if I can get that method working too, just for learning purposes
    Nov 2017
    591
    Quote Originally Posted by tom o View Post
    That's one option, but I don't think it would be easier than just having a few lines and solenoids. An articulating coolant nozzle sounds more complex to me, also easier to direct coolant right where I want it with multiple lines. Other problem is, I wouldn't be able reach all the tools with one programmable nozzle
    Dec 2013
    5717
    Quote Originally Posted by QuinnSjoblom View Post
    I've never written a macro. But in other programming I normally use case select if there are more two possible conditions, the logic is just easier for me.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    591
    Quote Originally Posted by Jim Dawson View Post
    Yep, case select probably makes the most sense for this.
    I also came up with another option for my tool offset macro that is pretty simple:
    If tool > 99 then
    code "G59P" & tool
    end if
    This basically applies an offset to every tool above 99 that matches the tool number. For example tool 110 would get offset G59P110. Kind of makes things convenient since the offset matches the tool, so there's never any confusion with being in the correct offset. Downside is I have to match the offset for groups of possible tools in same location, but I can just position at 0,0,0 and zero each offset for the group.
    Actually that script would also need code g54 when tool is less than 100 so it puts it back to regular offset when it changes back to a tool under 100
  1. New to using Macros
    By 905xray in forum G-Code Programing
    Last Post: 06-13-2019, 05:52 PM
  2. Macros!
    By Picomax in forum Uncategorised CAM Discussion
    Last Post: 12-09-2008, 09:56 AM
  3. X3 CNC macros
    By trainfred in forum Syil Products
    Last Post: 05-21-2008, 01:42 AM
  4. help with macros
    By gj83 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-12-2008, 02:42 AM
  5. macros
    By bob@apc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-04-2008, 06:42 PM
