603,896 active members*
5,248 visitors online*
Results 1 to 19 of 19
    Jun 2003
    115
    Need some math help...
    Well actually what I need is a little more than simple math...
    Is there a site with information or a sample calculation on how to obtain the torque and rpm needed to move a gantry with a x weight?
    What I need is a a procedure to calculate what servos I'll be needing. having:
    a. the weight of the gantry
    b. the max cutting speed
    c. the max repositioning speed
    this is for a plasma table, so there will not be reaction forces acting against the gantry as in a router table.
    Any help, is very appreciated...need to buy the servos right away
    Thanks,
    Hector
    Dec 2003
    24260
    Look at the servo manufacturers web sites for free graphic sizing programs, most are allied to their particular product but you can get pretty close and get a feel for what you need. e.g. http://www.electromate.com/technicalsupport/?c=software , parker-hannefin, www.motiononline.com , Galil.com Pacific-Scientific, Reliance Electric, Allen-Bradley, Electro-Craft.
    Al
    Albert E.
    Nov 2004
    78
    There are a few variables you need to know in order to figure this out:
    1. The friction of your linear axis.
    - are you using high quality linear slides, or something else?
    2. The friction of your screw.
    - an acme screw has an efficiency of around 36%
    - a high quality ballscrew has an efficiency of around 91%
    3. The weight of your gantry.
    For example, a hypothetical 10 oz-in (.63 lb-in) motor with direct (1:1) gearing to an acme screw with pitch of 0.25" will be able to exert about 5.7 pounds of force on whatever it is moving:
    thrust = gear mutiple * [1 / ( [(screw lead / 2*pi) * (1 / screw efficiency)] / torque)]
    thrust = 1 * [1 / ( [(0.25 / 2 * pi) * (1 / 0.36)] / 0.63)]
    thrust = 5.7 pounds
    (Note: if we used a 1:2 gear off the motor, we'd get double the thrust)
    I imagine that for a moving gantry with no other forces acting on it, the peak load on the motor is going to occur when you want to reverse the direction of the gantry very quickly (say within 50 milliseconds). If the gantry weighs 200 pounds (75Kg), and it is moving at a speed of 6 cm/sec (roughly 140 ips), then we really want this thing to change its speed by a total of 12 cm/sec
    (remember, it is reversing direction and accelerating back up to 6 cm/sec) within 50 milliseconds.
    Force = mass * acceleration
    So for acceleration of 0.12 m/sec / 0.050 seconds, we'd have F = 75*0.12/0.050 -- or F = 180N
    180N is about 40 pounds of force (1 pound-force = 4.448 N)
    So, in this case, with a 200 pound gantry we'd like to run at 140 ips and reverse direction in 50 milliseconds or better, our little 10 in-oz motor will not cut it. We'd either need to go directly to about a 100 oz-in motor, or we'd need to do a combination of the following:
    1. Use a higher efficiency screw
    2. Use a stronger motor
    3. Decrease the pitch of the drive screw (this will slow down our gantry, too)
    4. Use a lighter gantry
    5. Use a different gear ratio to drive our screw (this will also be slower)
    6. Relax our requirement that the gantry change directions in 50 milliseconds.
    We ignored friction in all of this, but if using a good linear slide, the variance shouldn't even be worth calculating.
    For just the gantry moving speed, as a separate calculation, you'd do this:
    linear speed = motor rpm / gearing * screw pitch
    Example: 2500 rpm motor / 1:4 gearing * 0.250 pitch
    = 2500/4*0.25
    = 156 inches per second
    Note: In our above example, if we did use a 1:4 gear, we'd get 32.5 pounds of force at the screw. We could then think about going to a 30 oz-in motor, and get 97.5 pounds of force, which should be plenty. We'd have 156 ips gantry jog speed, and we could easily push around a 200 pound gantry.
    -Chris
    Jun 2003
    115
    Hi Chris,
    Thanks for so helpfull information...regarding your comments,
    1. I'm thinking on using either camfollowers over a machined flat or v bearings over either regular steel angle or v railings(expensive! for a 6'x12'or20' table). I don't have a remotless idea on the friction on this kind of linear axis.
    2. Im planning to use rack and pinion in x,y,z axis, don't know which one is better 14.5 degree angle or 20 degree, and I don't know either what kind of friction they impose on the system.
    3. The weigh of the gantry, well, Im planning to do it from steel so it will be pretty heavy. the maximum speed for cutting is 240ipm, I'm building this table for a Hypertherm HT2000 High Speed Plasma.
    I'm planning to use servos with drive belt reduction...on x and y axis. for the z just a small dc motor, I'll be using the rutex 510 board.
    What kind of calculations will be involved in this type of design...in conclusion
    ---big table
    ---heavy gantry
    ---fast speeds
    ---rack and pinion
    ---v bearings or cam followers
    Regards,
    Hector
    Dec 2004
    524
    Quote Originally Posted by kanankeban
    Hi Chris,
    ---big table
    ---heavy gantry
    ---fast speeds
    ---rack and pinion
    Regards,
    Hector
    In addition to the forces associated with friction, don't forget to add in the force associated with acceleration. Most of the forces associated with friction are independent of the speed (I assume that you are not going so fast that air resistance is a consideration).
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Dec 2003
    24260
    The 20 deg. angle spur gear/rack takes a heavier load than the 14.5
    Remember on a horizontally controlled axis, especially if there is minimum side thrust as in Plasma cutting, the maxim torque required is not at rest or at final travel speed , but at acceleration & deceleration (inertia calculation) for very good design information, check out this site and if you get their free library of catalogue, half of them is dedicated to Engineering topics.
    http://www.sdp-si.com/D220/D220cat.htm#S1
    BTW are you driving both sides of the gantry? At that weight you may need to.
    Al
    Albert E.
    Nov 2004
    78
    ---big table
    ---heavy gantry
    ---fast speeds
    ---rack and pinion
    Regards,
    Hector
    Hector, the only calculation that has any importance is the force required to accelerate (and to stop) the gantry.
    Here is how to work backwards to a motor size specification. I'm going to do this entirely in metric (SI units), then we can convert the answer to Imperial units when we get toward the end.
    1. Determine the mass of your gantry, in Kg. You stated that the gantry is steel and pretty heavy. I couldn't even guess how heavy it is, so let me just pick a number of 400 pounds, or about 182Kg.
    2. Determine how fast you need this gantry to move. You said 240 ipm, so we will convert that to metric and say it is 610 cm/min or 11 cm/sec (rounding up).
    3. Determine how quickly the moving gantry has to be able to slow down to a complete stop, then reverse direction. In my other post, I used 50 milliseconds. I suppose we could also use 100 milliseconds (or maybe even 200 milliseconds). It depends on what you are milling. For me, doing woodworking, I don't want a router bit to linger any more than 1/10th of a second when cutting a hard wood like maple.
    Okay, so now we have the mass of the gantry, its constant speed, and how quickly we need it to come to a stop, then reverse direction. Let's look at the formulas:
    1. F=ma (Force equals mass times acceleration). Again, if we say that we want the gantry to completely reverse direction in 100 milliseconds, this means that we are doing this:
    - traveling at 11 cm/sec
    - coming to a dead stop
    - traveling in the opposite direction at 11 cm/sec
    - doing all of this in 100 milliseconds
    So, the net change in acceleration is 22 cm/sec (since we are reversing direction), and we need to effect that change in acceleration in 100 milliseconds. Our gantry has a mass of 182Kg, so the equation is:
    F = 182 * 22 cm/sec / .1 seconds
    This reads as "Force equals 182 kilograms times 22 centimeters per second, per 100 milliseconds"
    One minor touch-up (since SI deals with meters, not centimeters) is that we will convert 22 cm/sec into .22 m/sec:
    F = 182 * .22 m/sec / .1 sec
    Solving, F = 400N (Newtons, the SI unit for force).
    So, we need a drive system that can impart 400N of force on our gantry. How do we build such a drive system? Read Arvid's (Arvidb) white paper for the details, but in summary you need to select a screw pitch and step-up pulley system that will give you the force you need at the screw. At this point, I'm going to convert 400N into Imperial units. 1 pound-force = 4.448 N, so our 400N turns into 90 pounds-force (rounding up).
    So we need a drive system that can impart 90 pounds of force at the screw. Well...that cuts it too close, so let's pick a multiplier to give us enough headroom (for friction, or mabye the gantry isn't perfectly level, etc.). Let's use 2x as the multiplier, and agree that we need to generate 180 pounds of force (or 'thrust'):
    The rest of this will be in Imperial units.
    (gear multiple * motor torque) = thrust * (screw lead / 2*pi) * (1 / screw efficiency)
    or
    motor torque = (thrust * (screw lead / 2*pi) * (1 / screw efficiency)) / gear multiple
    We need to pick a couple of values, so let's use:
    gear multiple = 3 (i.e. a 1:3 pulley configuration)
    screw lead = 0.250" (4 turns per inch screw movement)
    screw efficiency = 0.90 (ball screw)
    solving the equation:
    motor torque = (180 * (0.250 / (2 * 3.14)) * (1/0.90)) / 3
    motor torque = (180 * 0.0398 * 1.11) / 3
    motor torque = 2.65 lb-in, or 43 oz-in
    So, for this example, it says that a 43 oz-in continuous torque servo motor will work. You'd need to run that motor at around 3000 RPM to end up with 240-250 ips linear speed through that 1:3 gear and 4 TPI screw.
    -Chris
    Jun 2003
    115
    Hey Chris,
    Thanks so much for so usefull information, now let me get some time to fully understand the process, and I will come back with some more doubts for sure
    Regards,
    Hector
    Dec 2004
    1137
    Simple calc
    WoodSnarfer,
    First, thank you for posting such complete (as far as I know it's cmplete ) example. I have taken your equations and put them in an Excel spreadsheet. My goal is to get your help in confirming/authoring the spreadsheet to a final form, then convert it to a php web form for universal use.
    Please have a look and let me know if this would be something your would want to work on.
    Jay
    Attached Files Attached Files
    Nov 2004
    78
    Jay,
    It's not 100% complete. That's why I throw in a 2x 'fudge' factor. To really do this the right way, the set of equations should take into account:
    1. the mass, diameter, angular velocity and acceleration of the drive screw(s).
    2. friction (for every contributor of friction in the system).
    3. estimated peak cutting force required.
    Even after that, we'd probably throw in the 2x 'fudge' factor, since it's never a good idea to spec anything at the hairy edge of your math results.
    I learned (well, relearned) most of this stuff from reading Arvid's white paper, which you can find here (and I think you've already seen) - along with revisting physics notes on the internet, and checking out manufacturer's product specs and engineering equations.
    http://www.cnczone.com/forums/attach...achmentid=4954
    But, even so...it would be pretty cool to have a web page that does the calculations for a given set of specs for an axis. I think such a utility ought to accept input in any form (Imperial or Metric), for any units (oz-in, lb-in, Nm, etc.) and be smart enough to do the appropriate conversions and spit out the answer in the format(s) the user wants.
    I had cobbled together a worksheet to help me evaluate motors...here's a screen shot if it helps you think about it at all.
    I'll work out the equation for screw angular acceleration/force and see if it can easily be added in to the mix...unless someone reading this beats me to it, of course
    -Chris
    Dec 2004
    1137
    Chris, I updated the spreadsheet (twice now ) after reading avidb's (while you were posting) whitepaper.
    Dec 2004
    1137
    Anyone care to provide feedback on the equations ... or is this a useless tool?
    Nov 2004
    78
    Jay,
    It's useful...it agrees with my version, so the math looks okay (or we are both wrong )
    It would really be useful as a robust web-based application, with context-sensitive help links (or mouse fly-overs).
    For the lead screw acceleration (and torque required), I found the formulas here:
    http://www.techno-isel.com/Tic/H834/...834P009_1.html
    I haven't had a chance to play around with it yet, but it would be interesting to see what the torque contribution to just managing the lead screw is.
    As an aside, after thinking about all of this, I've decided to run my servos at 22 volts instead of 50 volts. RPM will be down around 1300 -- but motor torque goes up, and the required gearing goes down to 1:1.5
    I'm thinking it is better for the motor to be closer matched speed-wise to the lead screw, from an acceleration point of view. Maybe a silly idea, but I like the idea of the motor having to go from 0 to 1300 RPM a lot better than having it have to go from 0 to 3500 RPM during cutting operations.
    -Chris
    Jun 2003
    115
    Quote Originally Posted by Jay C
    WoodSnarfer,
    Jay
    Hi jay,
    In my case, I will use rack and pinion and timing belts for reduction...in all three axis.
    What considerations do you think are required to adapt your excel spreed sheet?
    Regards,
    Hector
    Nov 2004
    78
    Hector, to use the equations for rack/pinion, you'd put in the lead for the pinion-to-rack ratio instead of the lead for a ballscrew. For example, if there is 2" of forward motion for every 1 revolution of the pinion gear, you'd put in 2 for the lead value (which equates to 0.5 TPI).
    Note that this is going to cause you to have to use an enormous value for the gear ratio off the servo, to get the pinion down to a reasonable rate of travel (and get the force up to where it needs to be). So, perhaps with rack/pinion you are going to have to have a gearbox of some sort off the motor, instead of using timing belts?
    If so, in the equation, you'd substitute the transmission efficiency of the gearbox in for the efficiency fraction of the ballscrew.
    -Chris
    Oct 2003
    399
    Is it possible to have several input cells in an Excel spreadsheet, where the other ones are updated depending on what is entered in any of them? I.e., to be able to enter mass either as kilograms or pounds, and have the other update automatically? I get a "cyclic dependancy" error when I try it...
    Arvid
  17. #17
    Dec 2004
    1137
    Quote Originally Posted by arvidb
    Arvid
    You can do if then statements. I have written sheets that look at one field for a marker (Like L for this and N for that) and calculate a result based on that. The spreadsheet I posted ws based on he working example by woodsnarf in this thread. I want to get all the possible equations first before adding the bells and whistles of entering in any units (SI or imperial) ... that's trivial to me. What is difficult, and only in a sense that I don't have any exposure to them, is all the forces and equations involved.
    I'm glad we have you here Arvidb
    Jay
    EDIT: here is an example of a excel cell
    Code:
    =IF(D6="L",+E6*3.6,+E6*1.2)
    This selects the voltage per cell (3.6V for Lithium Polymer or 1.2V for Nicd or NiMh cells) and multiplies it by the number of cells (E6).
  18. #18
    Feb 2005
    234
    I just wondering if you guys knows the application for these formulas or related CNC things on PDA ?
    what's they called and it's site ?
    regard
    rud
  19. #19
    Apr 2004
    678
    Quote Originally Posted by WoodSnarfer
    -Chris
    The torque does not go up with lower voltage, it goes up with higher current. So your assumption is only true if you have limited power (volt*ampere) available.
    Acceleration needs torque. If you design with max RPM equal to max speed of your machine, there will be no potential to drive current when close to max speed. And so the acceleration will fall off with speed. If you have a higher voltage available, it can be used to keep up the current (=acceleration) all the way up to max speed before levelling off.
    You need voltage for 2 purposes:
    1. To make the motor go fast.
    2. To create the current that makes it push something, or accelerate.
    This also means that although it can turn itself 1300RPM, there may not be enough voltage to create the current needed to actually do work at 1300RPM. So you need a higher voltage to be able to run 1300RPM against the friction and cutting forces (that a plasma cutter does not have).
    Usually the speed calculations are made based on having full torque even at your max speed. So you need a good voltage overhead. 48V is probably a good choice if your amplifiers/drives are specified for that, as 48V is in most places a limit above which you have to follow other, more stringent safety rules.
  1. units per inch math
    By gearcut in forum Mechanical Calculations/Engineering Design
    Last Post: 05-29-2005, 07:02 PM
  2. Stepper Math questions...
    By Aegeon in forum Mechanical Calculations/Engineering Design
    Last Post: 04-28-2005, 04:22 PM
  3. math needed to build a cnc
    By trubleshtr in forum Mechanical Calculations/Engineering Design
    Last Post: 03-16-2005, 08:20 PM
  4. Motor math...am I doing this right?
    By WoodSnarfer in forum Servo Motors / Drives
    Last Post: 11-22-2004, 01:13 PM
  5. Timing Belts Math...Help!
    By kanankeban in forum DIY CNC Router Table Machines
    Last Post: 11-02-2004, 04:19 AM
