587,842 active members*
3,425 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
Hybrid View
    Jul 2010
    1328
    need suggestion
    Have a brand new plastics bit... My only one (had an 1/8" one but immediately broke it because of wrong feeds and speeds)
    Amana Tool 51404 Solid Carbide Spiral 'O' Flute, Mirror Finish, Plastic Cutting 1/4 Dia x 3/4 Cut Height x 1/4 Inch Shank Up-Cut Router Bit
    Gotta cut a couple circles in 1/4" acrylic today...
    Have 'no idea' where to set feeds and speeds and DOC...
    Suggestions of a good safe starting point?....
    Apr 2006
    3206
    Why not post what your "wrong" feeds and speeds were that you believe caused the failure?
    Acrylic is a whole lot softer than cutters, so if it breaks, it's 99% of the time chips sticking to the cutter and/or not clearing, so it's a mechanical failure.
    THE very first thing you want to do is make sure you've got good air flow at the tool/material interface to keep the material from melting onto the tool and to clear the chips. Flood coolant works fine too.
    May 2004
    4519
    Problem I always have with plastics is melting. Heat is cause by friction. Reduce friction you reduce melting.
    Apr 2006
    3206
    I can't imagine that using the speeds and feeds for HSS on aluminum wouldn't work as a very safe and conservative starting point along with good air flow for cooling and chip clearance.
    It's worked for me in the plastic jobs I've done where I'm making a model in plastic and then a part...without having to post twice.
    Sep 2006
    340
    Just use a 1/4" drill? It'll make a circle. Lol..
    Hey check out my website...www.cravenoriginal.com
    Thanks Marc
    Mar 2003
    35538
    10,000 rpm and 80-100 ipm.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2010
    1328
    Thanks Gerry... Cut the whole 1/4" DOC in one pass, or should I split it up into two passes?
    Mar 2003
    35538
    I'd say make 2 passes until you get a feel for it.
    Gerry
    Jul 2010
    1328
    Cool thanks.. What I was planning on doing anyways if I got no reply in time...
    thanks!
    :cheers:
    Feb 2008
    231
    I have cut a LOT of plastics and acrylic sheet this year. The one thing that got me to success consistently with all types of bits/speeds/feeds was to put air cooling (shop compressed air) blowing directly on the bit. Not only does this cool the tool but more importantly it totally clears any chips from recirculating back around into the tool and melting. I set up my router so that the tiny brass air line is part of the vacuum hood. I have a needle valve installed to adjust the air volume. I will post a pic in a few.
    Scott
    Feb 2008
    231
    The setup works like such. When the router comes on the 110VAC that turns on the router also energizes an air valve that starts the cooling air flowing to the tool. The brass tube is pinched down to deliver a high velocity stream of air to the tool. The brass valve controls the air volume. The same 110VAC turns on the 2HP dust collector machine so that it all starts/stops when Mach turns on the spindle output. This setup has proven VITAL to cutting sheet aluminum as well as plastics. The aluminum plate attached to the router in the first pic is a vinyl cutting attachment, I remove the dust collector when I am vinyl cutting.
    Scott
    Sep 2011
    1183
    Wink
    Mark I cut my Acrylic at 8000 rpm 100 in per minute feed rate and I do it in two passes and I use tabs..
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
    Mar 2003
    35538
    I also don't see how the vacuum could be making your router hotter??? I would expect that if the router were turned off, and the Z axis lowered until the brushes touch the table, that the vacuum would actually pull some air through the router itself.
    Unless you have a really unusual setup, I'd say that the vacuum has nothing to do with your hot router.
    Also, the Super PID should make the router run cooler, as it's more efficient that the standard speed control.
    As Louie says, unless you're pushing it really hard, you either have a bad bearing, or the airflow inside the router is really restricted.
    I can run my PC 690 all day and it barely gets warm at 13,000 rpm or less.
    Even when I crank it up to 16,000 when I use really small bits for carving, it won't get anywhere near hot even after 3-4 hours of use.
    From my experience, after 5-10 minutes, it should be about as hot as it's going to get. If it keeps getting hotter after that, then something is wrong.
    Gerry
    Jul 2010
    1328
    The router body does not get hot at all.. but after running it for a bit on aggressive cuts (ie profiling through wood), then the collet/router shaft gets pretty hot... almost too hot to touch... and the shaft will 'squeak' when turned as I'm tightening the next bit in... give it a few minutes to cool down and it doesn't squeak...
    Doesn't appear to be any run out or wear issues... Who knows.. maybe I got a funky one.... that happens to me a lot.. LOL
    It'll last till I get the rebuild done and go to a bigger router or spindle....
    Jan 2012
    Quote Originally Posted by Mountaincraft View Post
    It might. Then again it might not, so keep your fingers crossed. Except for the squeak, that sounds exactly like my current problem:
    http://www.cnczone.com/forums/diy-cn...nning_hot.html
    If it's the bearing, it will heat up just spinning full-speed/no-load for 4-5 minutes.
    Apr 2009
    5516
    I guess you'd have to define aggressive. I can cut all day with my 3/8" single edge compression spiral taking 3/8" doc at 150ipm, and grab the bit after three hours and it's cool to the touch. Toward the end of my old Bosch1617's life I started hearing a slight squeak in the bearing, so I had to take it easier on the router (i.e. less load) to make it last until the replacement. Bearings can be relatively inexpensive compared to the router's cost...
  17. #17
    Sep 2011
    1183
    My Hitachi runs cool I able to change tools right when the spindle stops for a tool change..
    Lou
  18. #18
    Jul 2010
    1328
    The shaft stop (for tool changes) sheared on this thing within about a month of when I bought it (seems to be the most ordered part), when I ordered a new one (actually I ordered two), I ordered a new top bearing..... I gotta check and see if it's the same part number for the bottom.. if so, I may already have the bearing to replace it....
  19. #19
    Mar 2003
    35538
    Sounds like a bad bottom bearing.
    Gerry
  20. #20
    Jul 2010
    1328
    Wouldn't be surprised... I buy my share of lemons........ :violin:
Page 1 of 2 12
  1. Need a suggestion on what cnc to Buy
    By CypherDragon in forum Want To Buy...Need help!
    Last Post: 02-13-2010, 06:30 PM
  2. Cam software suggestion
    By fidia in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-09-2007, 04:56 PM
  3. A suggestion
    By shreifali in forum MetalWork Discussion
    Last Post: 02-06-2007, 03:44 AM
  4. New guy and I need suggestion.
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 02-01-2004, 12:29 AM
