I have looked on various sellers on Ebay and Amazon and cannot find any 12mm 4 bolt flange bearings, tons of 1/2" though.
I need two of them.
Can anyone tell me where I can get a couple.
Hager
I need two of them.
Hager
Why not just go with 1/2" http://www.thebigbearingstore.com/se...-Flange/Detail
and make it work? 12mm is what, .47? 1/32 isn't a lot of play especially with 2 set screws.
Thanks for the suggestion but as you say 12mm = 0.474" that's 0.026" smaller than 0.500".
This would put added stress on the ball and the flex connection, I want to build as best I can.
If I can't find a 4 bolt 12mm flange then I have two options, (1) make a flange using HDPD (SP???) or (2) turn the 12mm portion down to say 0.250" and sweat a sleeve over it to bring it up to 0.500". The latter is what I'm leaning to.
See Drawing below.
When you are building out of found inexpensive parts there is always challenges.
Hager
(815)-654-1154 Address 9926 N Alpine Rd
Machesney Park Illinois, 61115
Berry Bearing Co. Has what your looking for. We had alot of metric machines at the plant. We called them and could get the bearing by COB.
They don't have a web page that I could find. Also try other bearing suppliers in your area.
Berry Bearing is part of Motion Industries.
https://www.motionindustries.com/mot.../mi/motion.jsp
I found his section.
