603,874 active members*
7,715 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Need a Viper emblem Drawing or Model
Results 1 to 5 of 5
    I have a jpg, is there any way to convert it to a DXF and insert it into solidworks for modeling??..I want to engrave the emblem into a part, but dont really have the drawing skills to make it,lol..
    or if anyone has seen a solidworks or Parasolid file that would work too..
    Visit my webpage www.cdignition.com
    Apr 2003
    97
    Sent the dxf to your email - lemme know if you needed the new one instead.
    I've got a ton of logos on file from past jobs, and within limits can vectorize anything of reasonable resolution.
    Hope it helps.
    Worry about success, failure takes care of itself.
    Oh, that perfect...thanks a million.
    How do you go about "vectorizing" a pic into a DXF file??...Im sure theres some kind of software involved, just dont know what,lol..
    thanks again..perfect..
    Apr 2003
    97
    I use Corel draw and recreate the image.
    It's not that hard - mostly you just pic out ovals and rectangle shapes and weld them together.
    If you can pick up a copy - couple hundred bucks off ebay - I will send you some tutorial drawings. Usually you can pick up the theory in one or two days and be proficient inside a week of work.
    Corel also has some of the nicest automatic vectorizing options I have seen. Even if you do not believe you can redo one from scratch you can get very close from the automatic option.
    In the meantime - just post anything you need. Keeps me in practice.
    Mar 2003
    779
    We use TracTrix to convert Raster to Vector. It works pretty well.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
  1. Problem with drawing? or CAM?
    By CNC Darren in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2005, 06:30 PM
  2. Solid model to CNC code quession
    By mikenelson in forum Uncategorised CAM Discussion
    Last Post: 07-08-2003, 03:55 AM
