588,204 active members*
3,912 visitors online*
    Need a worm gear cut
    I have a Sibley C-20 drill press that needs a new feed worm gear. What is left of Sibley retains zero knowledge of the Sibley drill presses so I can't get the gear from them.
    I have cast a new blank and need someone to cut the teeth. I have the OEM print that specifies" 66T, .250 C.P. 12.556 D.P. the OD of the gear is to be 5.448", Troat diameter of 5.410" and a 5.252 P.D.. The gear face is 1" wide.
    the gear I need is actually on the second page of the pdf.
    Andrew Abrams
    Marcellus Metalcasters, Inc.
    Feb 2007
    6
    Re: Need a worm gear cut
    Quote Originally Posted by metalcaster4jc View Post
    Hi, do you steel need these parts? or do you have any new inquiries?
    If you do, please send drawing to [email protected]
  1. worm gear
    By fero786 in forum Uncategorised MetalWorking Machines
    Last Post: 12-23-2013, 07:27 AM
  2. worm gear
    Last Post: 12-21-2013, 02:31 PM
  3. Horizontal Saw Worm Gear
    By Shanghyd in forum Want To Buy...Need help!
    Last Post: 01-30-2010, 02:54 AM
  4. Worm gear and worm drive
    By LEWENZ in forum Employment Opportunity
    Last Post: 04-27-2008, 10:28 PM
  5. Worm Gear
    By jackson in forum MetalWork Discussion
    Last Post: 02-07-2008, 10:25 PM
