I recently ordered a NEMA 34 stepper motor and found the shaft diameter was 0.62" diameter. I was under the impression all NEMA 34 motors had a 0.50" diameter shaft.
Just curious if the NEMA spec specifies shaft diameter, or is it just the frame mounting dimension?
