Re: New 2x4 Saturn build
Good stuff, Dan. I like the dual touch plates and the prompting that Acorn gives for changing bits, putting the dust shoe back on, etc.
A couple of observations - at 0:26 in the first video it appears Acorn has a 'tough' plate and a 'touch' plate in the same dialogue box - LOL! Typo, Acorn...
How close did your bit come to the lower left clamp knob? It looks close in the video. Do you have to specify where those are and how high in Vectric or does it tell you where to place them?
It appears your Z ballscrew isn't lubricated. Are you planning to do that or is it just lubricated up where we can't see it? Mine is well greased, fwiw, as well as the linear bearings and R&P.
In the second video, did you set your ramp speed that slow or did Vectric? That looks slow enough to burn instead of cut. I set my ramp at the same speed as I cut. I figure if it can cut at the speed and depth of cut I've chosen then it can certainly ramp at that speed.
Did you cut that without tabs or did you remove them off camera? If I cut without tabs the piece that's now loose gets caught by the bit every time.
That's a very smooth running machine - good job!
David
David
Romans 3:23
Etsy shop opened 12/1/17 - CurlyWoodShop
