603,890 active members*
2,900 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > New Build, 3-axis baltic birch. Hardware finished~ what CAM/CAD?
Results 1 to 9 of 9
Threaded View
s3648 New Build, 3-axis baltic... 05-21-2009, 02:11 PM
analogman For CAD, I really like... 05-21-2009, 03:57 PM
madtownrob How about VCarve Pro if you... 05-21-2009, 04:02 PM
ger21 V-Carve Pro is definitely... 05-21-2009, 04:06 PM
s3648 Thank you GER21, I am pretty... 05-21-2009, 05:25 PM
EdinSimon This is a nice looking setup,... 05-21-2009, 05:49 PM
s3648 Hi simon, thank you. I will... 05-21-2009, 06:05 PM
ger21 Definitely Mach3. Here's a... 05-21-2009, 06:37 PM
s3648 I cut all the "holes" out... 05-21-2009, 10:01 PM
    Nov 2008
    14
    I built this router table over the last 6 months or so. Using real baltic birch (NON-CHINISE) and the skate bearing linear slides. I used the standard newbie 1/2-10 amce leadscrews and probotix steppers. I built the McWire design Circuit with resistors instead of lightbulbs.
    Now the problem. I have my router running fine with the free k-cam. But will need to purchase controll software (turns out 250-500 lines of g-code is a grain of sand in a dessert!) and I have scoured CNCZone on this subject, but most of the posts are from 2006 and do not consider the software upgrades that have happened since.
    My Intended Use: Woodworker by trade. I am invisioning carving panels for cabinets, maybe some jointery, some signs. Milling parts for jigs and such. (of course using it to build my next cnc machine!!)
    I own and am fluent in:
    AutoCAD R14
    Sketchup
    Photoshop
    so here is what seems to make sense to me:
    1. Kellycam works great, but doesn't seem that most CAM programs post to it. I thought about Freemill and KCAM but that wont do text very easy.
    2. The hobbiest standard seems to be Mach3. I am good with that, however, CAM programs are new to me. I have downloaded and played with MeshCAM, SheetCAM, CamBam , and LazyCAM plus.
    Seems to me meshCAM+Mach3 bundle ($300) is more geared to what I'm trying to do.
    Anybody out there been there, done that?
  1. Finished my Taig 4th Axis
    By fretsman in forum Taig Mills / Lathes
    Last Post: 12-31-2008, 05:33 AM
  2. Build #2: 3 axis open table, Baltic birch
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 07-29-2008, 05:35 AM
  3. Baltic Birch ply + MDF build, which material for which part
    Last Post: 06-25-2008, 12:21 PM
  4. One place to buy all require hardware to build a cnc router?
    By jimmyaz in forum Open Source CNC Machine Designs
    Last Post: 10-10-2007, 12:11 PM
  5. 'got my Z axis finished...
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 08-14-2006, 12:23 AM
