Buyer Beware: Please read complete thread before dealing with CNC Conversion Kit on eBay or CNCCONVERSIONKIT.com or CONVERSIONCNCKIT.com. And please keep in mind the original ship date promised for the complete machine was 4 days after payment. It is now going on 30 days and I still don't have everything. And many of the parts that I do have are wrong or of extremely poor quality. Just a word of warning if you plan on dealing with the aforementioned company. It has been and remains an unpleasant experience working with CNC Conversion Kit to get all the issues resolved and I don't want anyone else having to go through it if possible.
Intro:
I just recently sold my CNC plasma system to fund a machine that is better suited for my needs. I decided to go with a router for better cut quality on aluminum sheet and added versatility having a spindle brings. Coming from the 36" x 36" plasma I didn't want to reduce my working envelope much so I found a machine in that size range (sort of).
I found my machine on ConversionCNCkit.com, a company up in Canada.
Mfg.:
CNC Conversion Kit seems to offer their routers in a plethora of configurations; from the smaller more basic models, to the decked out higher quality component editions. I opted for the latter. Peter, my contact with the company has been very helpful throughout the ordering process and worked with me on the pricing and upgrading a few features on the machine.
Specs:
- 26" x 41" x 6" working envelope
- 60mm x 60mm extruded aluminum frame
- 1/2" and 3/4" Mic6 machined aluminum parts
- dual ballscrew Y axis
- Supported rails
- 1.5kW 220V spindle (ER11 and water cooled) + VFD
- Gecko G540 and upgraded 48VDC 12A power supply in aluminum control box
- Four (4) 380oz./in stepper motors
- Upgrade: full width T-slot table (only half shown in picture)
Application:
I'll be using this machine mainly for cutting aluminum sheet (5052H32) for fabrication custom aluminum computer cases. The plasma did a pretty good job of this, but lacked the refined finished cut of a mill or router. The aluminum also tended to warp with the heat and cut finish required a lot of filing and grinding, but the finished products looked good.
Having a router will also allow me to work with more materials like polycarbonate, woods and other machinable non-ferrous materials. And with the added control and precision of a ballscrew setup rather than rack and pinion, cutting will be much more accurate and predictable.
Future Plans:
The machine will not arrive until as late as the 3/18, so I have time to prepare my shop and gather my thoughts on how design the bench and cabinet for the machine, as well as order all my tooling and misc. items on my shopping list.
I've already ordered some tooling as well as an ELO touchscreen monitor, but I've quite a bit left to do before I'll be ready to setup the machine itself once it arrives.
To Do:
- run 220V to basement
- build bench for machine
- build control box (will probably use old PC tower case; HEC98)
- order tooling, collets and worklights
- design means of chip/coolant containment
Stayed tuned! I'll be posting updates as I go with plenty of pictures.
