588,228 active members*
4,451 visitors online*
    Feb 2011
    102
    New G251X drive
    I am using the new G251X drive. These are good low priced alternative to imported drives. They are $69 each in small quantities. They are good for steppers rated at 3.5 amps/phase or less. They are not plug and play though. They require mounting, heat sinking, and optoisolation, but that's what DIY cnc hobbyists want. I was surprised that there was not a thread already started on this drive. I am already using them in a project in a thread here titled "Interfacing MO-CON501 controller/Little blue box."
    Mar 2003
    35538
    Everybody usually uses The G540, which has 4 of them, and additional features, for less money than they cost individually.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2011
    102
    G540
    Definitely better to buy the G540 as long as you are going the standard route of interfacing with a parallel port but for instance I am interfacing with DSP controller with it's own interface board--maybe I will wish I just went ahead and bought separate G203V or one of the others but I'm glad Gecko made the G251X available so that the technical sophistication and quality of these drives is available for DIY projects at a price competitive with imported stuff. Anyone with experience in interfacing and protecting these drives please post, but I'm thinking that everything you need to know is here in these forums. Just need to know how to apply it. I will post a schematic when I'm done if all turns out well.
  1. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  2. G251X for Xylotex 425oz?
    By Rees Guitars in forum Stepper Motors / Drives
    Last Post: 05-10-2011, 03:12 AM
  3. Clausing Lathe Conversion, direct drive or reduced drive
    By Marty_Escarcega in forum Stepper Motors / Drives
    Last Post: 03-16-2010, 04:43 PM
  4. Direct Drive Plasma - Motor/drive/power supply?
    By CPierce18 in forum Waterjet General Topics
    Last Post: 02-06-2010, 12:53 AM
  5. Replies: 3
    Last Post: 07-04-2008, 12:57 AM
