Can anyone tell me if the spindle is actually R8? I want to order some tooling.
anyone want to defer theirs to San Francisco, let me know. Mid June is almost next year in my book. I might lose interest.
same thing happened with my g0602 lathe. Took 3 months to get that thing. Was just about to order the sx3 from grizzly when i saw this post. Sooooooooooo should i get this instead? Planned on getting the setup CR recommends on his site for the cnc conversion. Any advice?
I apologized for that post, because I knew nothing about the mill other than the specs.
After seeing some of the first hand accounts, it seems that just about everything I said is true. I now stand by my comment that this mill is sized somewhere between the X2 and the X3. It DOES have larger X travel, and is made very well though.
The only design fault I know of with the SX3 is the column flex, and that is totally taken care of with a proper brace. I would recommend the new SX3 with 21 inch table travels if you need a larger mill.
https://www.machinetoolswarehouse.co...L-p-16279.html
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
its more than column flex. the rear mounted ball screws, short z saddle and tiny shallow dovetails make for binding and twisting on the z. throw in that the ways are often not even parallel and you have limited accuracy on the Z. the gibs are not taped like the weiss models and the Y axis dovetail is inverted which has its own issues with gibs.
so, yes, the weiss is smaller, but i would venture to say its more capable based on everything ive seen of it.
anyhow, not the point here to knock the x3 as wel lall know is worked well for many. the point was that one shouldnt discount the g0704 mill because of your incorrect comments
I have not experienced any of these problems with my Grizzly SX3. Maybe the HF models had them. The SX3 has a full tapered Z gib--Not the same on the X3. I would love to have them on X and Y as the G0704 has though.
Maybe so, but smaller is less capable in many ways.so, yes, the weiss is smaller, but i would venture to say its more capable based on everything ive seen of it.
Please explain which of my comments are incorrect and why?anyhow, not the point here to knock the x3 as wel lall know is worked well for many. the point was that one shouldnt discount the g0704 mill because of your incorrect comments
CR.,
The main reason I choose to buy a BF20 mill a year ago was I already owned a Seig X2, and wasn't greatly impressed (spent more time adjusting it than using it, in all honesty needed a bigger mill). I also previously owned a couple of Seig mini lathes which were also less than impressive (mod heaven, always adjusting this or that, again needed something with more base capability). In my opinion design and build quality trumps weight when the machines are in the same general size class; and from my experience, as well as others in the thread, the BF series has a good design and build. (When I need a mill all I have to do is set the job up and run with it, the mill is ready to work). To be fair, I have never owned a Seig X3, so I can't comment from experience on this particular offering from Seig, just as I would imagine people who do not own a BF series can fairly comment on a machine they have no practical experience with. Also, in all fairness the Seig X3S does appear to correct some of the deficencies of the original design, for about a $400 price increase. I am however glad people in the USA are now being offered reasonably priced Chinese machines from more than just one supplier/factory/school of design, maybe the Chinese are becoming Capitalists after all.
Ah, Grizzly has started a small mill battle it seems.
Lets compare shall we.
G0704, for $950 you get 1 HP, 2250 rpm, nearly 19 x 7 travels, 7-1/8 x 26-5/8 table and a free stand.
G0619, for $1295 you get 1 HP, 1750 rpm, about 16 x 5.75 travels, 6-1/4" x 21-5/8 table, no stand.
Seemed like a no brainer to me too.
Now one can argue about bracing this and modding that to try and even things up, but what can be done
to one can also be done to the other.
Sieg must be getting worried, they came out with the extended table for the X3 as I pointed out
a couple weeks ago at MTW.
The BF's have had L versions for quite a while.
Betcha HF unloaded the X3 to make room for a BF too.
I said it before and I'll say it again, the BF's are our future.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
