587,600 active members*
4,491 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > New to this help needed!
Results 1 to 11 of 11
    Dec 2006
    39
    Unhappy New to this help needed!
    Hello to all.
    I am currently building a cnc router table for my model making and I am a little stuck .
    I'm looking at running Mach 3 for control but I need to figure out how to scan the plane parts and clean this image up then convert to g-code.
    Any takers on passing the wealth of knowledge on?
    Jan 2006
    4396
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Dec 2006
    39
    thanks to your reply. I was a bit of target with my first question.
    I currently have drawn plans which came from a model mag and I need to scan these. Once these are scanned I need to remove the woodgrain lines and just clean them up. Then convert them to g-code.
    is there any program or programs that you guys would recommend for this task. If there is a step I have not though of let me know.
    Currently :drowning: in a pool that brain mush that need sorting out.
    Dec 2006
    Hello
    Mar 2003
    35538
    For best results, I'd redraw them in a CAD program. It is possible to scan them and use a raster to vector converter to get a .dxf file, but they usually give poor results that require much cleanup.
    My preferred method would be to scan, then load the image into a CAD program as a backdrop, scale the image to actual size and then trace. Although if you have enough info, I'd skip the trace and draw from scratch. Depends on your CAD skills too, though.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2006
    4396
    Gerry has a good point. I'd stick with that if in your shoes. It seems to be the best way to do this.
    Do you have a CAD or CAM Software to do this with?
    Toby D.
    Schwarzwald
    Dec 2006
    39
    Thanks guys,
    Currently I have turbocad V9.2 as this was a left over for someone at work. Is there a program more suited to my needs than this?
    Jan 2006
    4396
    Mastercam
    BobCAD/CAM
    BobArt ProX
    Rhino
    Solidworks might have something
    Catia V5 is awsome, but who can afford that?
    There maybe more, but these come to mind.
    Toby D.
    Schwarzwald
    Dec 2006
    Mar 2003
    35538
    Quote Originally Posted by Coolcuttings View Post
    Thanks guys,
    If you're going to redraw the parts, that should work fine, if it has the tools you need to accurately draw your parts. Then you need a CAM program to convert the drawing to g-code. You might want to look at www.sheetcam.com
    Gerry
    Dec 2006
    39
    Thanks Gerry,
    I have downloaded the trial and will be working with that soon.
