603,785 active members*
17,545 visitors online*
    Feb 2009
    101
    New mill setup with Mach3
    Hello all. I am setting up a Novakon NM-135 (KX3) CNC mill and I could really use some help setting up Mach3 for the system.
    What parameters need to be programed into Mach3 to get the system up and running?
    Thanks for the help.
    -Blane Nelson
    www.tacticalpyrotechnics.com
    Jul 2007
    1602
    Have you downloaded the XML setup files from Novakon? They are probably a good start. Once you have things running you can tweak them based on your experience and feedback from other NM 135 users.
    http://www.novakon.net/10.html
  1. Mach3 Wont Run - Setup Help
    By Cosha in forum Machines running Mach Software
    Last Post: 02-26-2008, 04:48 PM
  2. Mach3 R3.00 Mill 4 axis Foam cutter setup
    By Andy Smith in forum Mach Mill
    Last Post: 01-25-2008, 02:19 PM
  3. Mach3 setup
    By mlaws1172 in forum Mach Plasma / Laser
    Last Post: 11-30-2005, 05:14 PM
