588,202 active members*
4,622 visitors online*
Results 1 to 6 of 6
    Nov 2004
    436
    New motherboard/processor
    I just order a new motherboard/processor to repair my old one, and I would like to know how the collective thinks it will work for Rhino/Mach3 operations.
    Motherboard: Ecs Geforce6100SM-M MB
    Processor: Athlon64 X2 5000+ Socket AM2
    RAM: PC 5300 667MHZ RAM (two 1GB sticks)
    I will still be running an old AGP Nvidia Geforce 4000 video card.
    In order to do this, I finally bought a DB25 breakout board WITH the pull up resistors installed.
    Opinions, anyone?
    Apr 2007
    16
    Plenty of power there
    Apr 2005
    3634
    I guess you want the power for "Rhino" (Processor), I'm thinking Mach3 will fly with 1/2 that!
    How much did the Processor cost?
    What OS are you running?
    I setup a PC this last weekend for a family member, it was running Vista, made me think of "Windows ME" (dressed up Win98), only Vista keeps asking for permission for every little thing. I only worked on it long enough to set the thing up. I guess you have an option to disable the nagging popups (Not that I need a remedy)?
    I'll be sticking with XP for a long while!
    Apr 2005
    1268
    Most certainly it will not have a parallel port for conventional hookup. Don't forget to buy a card (if you need one!!!).
    Good luck with the new system. Keep us posted. Bout time to retire my old junker and bring in the new!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Nov 2004
    436
    The motherboard/processor/ram combo costs under $400 through www.pricewatch.com .
    I do not run mach through that cpu, I decided to put together 2 systems.
    My old system, athlon xp2600, asus a7x motherboard with 1gb of ram is running mach just fine. I do not need to use the new breakout board (w/ pullup resistors) because it is a late model motherboard that still drives 5v TTL.
    People have been telling me that unless I run multiple applications at the shme time, I will not be using the "Duel Core" at all. That kind of bums me out, because I thought I was paying to use twice the cpu power. I only have 2.6ghz with this setup. Oh well, live and learn, right?
    For now, it does just fine with Rhino and Rhinocam. I wish I could say that I saw a marked improvement between the old 2.2ghz w 1gb ram and the new 2.6ghz with 2gb of ram, but I do not yet see it.
    It actually boots slower since I had to reinstall windows to get the hard drives to work again. Typical when upgrading motherboards. I think I need to tune and tweak windows again.
    Apr 2005
    3634
    Quote Originally Posted by spoiledbrat View Post
    Thats not true, you could have a single program running multiple threads, & XP supports that.
    I'm sure most graphic programs (Rhino) have more than one process (thread) running at the same time while the program generates the image/images you see on the screen.
    Better to have, than not have the dual processors.
    Besides you might not realize it, but I bet your running more than 1 app. right now, espically If you have DSL.
  1. Newb with Bridgeport BMDC/motherboard issues
    By ralph@nes in forum Computers / Desktops / Networking
    Last Post: 02-27-2007, 12:57 AM
  2. Processor
    By 1cnchogger in forum Haas Mills
    Last Post: 01-18-2007, 12:41 AM
  3. Haas controlers, the PC104 motherboard and DOS...
    By crayner in forum Haas Mills
    Last Post: 12-22-2006, 12:10 AM
  4. NC Post Processor
    By dannyboysd89 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-04-2006, 12:26 AM
  5. Mach 3 and ITX Motherboard?
    By DennisCNC in forum Mach Software (ArtSoft software)
    Last Post: 11-22-2005, 04:04 AM
