603,790 active members*
2,972 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > New Owner of Novakon NM-200 series 1
Page 4 of 4 234
Results 61 to 64 of 64
  1. #61
    Jun 2004
    6618
    Re: New Owner of Novakon NM-200 series 1
    Now that I might even come in on. I have a round column type mill that takes up space. Light rust everywhere due to a fire. Otherwise brand new Chinese machine. Clarification. It was not the heat of the fire that cause the rust. It was mainly the fire ext. I used and then had a bit of water added by the FD.
    Lee
  2. #62
    Oct 2012
    342
    Quote Originally Posted by hayes View Post
    Dan,
    If you're serious about this, please let me know, I'm very interested! Also, we might consider a new column casting or polymer concrete filled steel column. I can't believe how much flex there is in the column. I'm getting .002" in either Z+ or Z- directions just with hand pressure. I've checked torque on all the column bolts, and everything is tight.
    Cheers,
    Josh
    My professor was out sick tonight so I had a little time while "watching" the video the sub put on. I started over on the new head casting. It may not look like much but its a very solid start, 3 vertical and 3 horizontal ribs and plenty of cast iron to allow the end user to build to the way they want. I will keep plugging away at a complete design with the intent of being used just for the BT30 spindle cartridge. It will require a new top plate and the end user to design their own draw bar release method.
    -Dan
    Attachment 272604 Attachment 272606
    Attachment 272608 Attachment 272610
Name:	New Headstock Casting 5.PNG
ID:	272612 Click image for larger version.
Name:	New Headstock Casting 6.PNG
  3. #63
    Dec 2013
    72
    I dig it! I do have a question though as I just don't know the answer - what would be better from a manufacturing, cost and rigidity perspective - a steel weldment or aged and hardened cast iron casting?
  4. #64
    Oct 2012
    342
    Well aside from the cost of making the pattern for sand casting, a casting should be much cheaper than a fabrication like this. But making a pattern basically takes as much effort as a fabrication except in wood. I am hoping to I might be able to use the lost foam method and fabricate a copy of the headstock with the foam that is then packed with sand and when the iron is poured in the foam vaporizes.
    A weldment will not absorb and suppress vibrations like a casting will. Plus a weldment will need a thorough stress reliving before machining. Additionally to make a mill headstock like this will take a fair amount of time and some expensive pieces of steel. I took a quick look for the steel stock (all higher grade than A36) and I came up with $400-500 in raw stock before cutting, fabricating, welding, heat treat. Stepping down to A36 cuts the cost down to $250-400.
    Sometime in the next couple weeks I am going to stop a local foundry that does small odds and ends parts too see what they think of the design I have come up with and see if they can give me a ball park price. At that point I will take a serious look at what path I want to go down.
    -Dan
Page 4 of 4 234
  1. Novakon Series II & Accessories
    By jvduggan in forum Novakon
    Last Post: 10-26-2012, 12:46 AM
  2. Replies: 32
    Last Post: 02-27-2011, 07:09 AM
  3. New Tormach Owner - Video Series
    By tikka308 in forum Tormach Personal CNC Mill
    Last Post: 11-02-2010, 02:17 PM
  4. Novakon Announces NM-200 Series 2 Pro Mill
    By Novakon in forum News Announcements
    Last Post: 04-14-2010, 04:42 PM
  5. Need help from a Series I CNC owner.
    By chrispy in forum Bridgeport / Hardinge Mills
    Last Post: 08-31-2005, 02:45 AM
