588,522 active members*
7,786 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Jul 2007
    189
    New printer build
    My extruder experiment came out great and so I decided to go ahead and build a dedicated 3D printer
    http://www.cnczone.com/forums/genera...c_machine.html
    Build specs
    8 x 8 x 8 inch print bed
    Frame is 1 inch T slot
    Bearings are T sot linear bearings - no screws, no smooth rods
    GT2 drive pulleys and belts'
    Nema 17 motors
    Probotix drivers, breakout board and power supply
    gnex lab dual temp control board for hot end and heater bed
    8 inch silicon heater bed
    I will run the code on Mach3
    I cut the T slot pices today and did a rough fit to see how it looks
    I don't have the UHMW-PE bearing material for my bearing blocks yet and so I just used cardboard for the mock up
    Here's a pic of the progress so far
    Jul 2007
    189
    I got the X axis up and running today and took a movie of it in action
    (The 3D printer crowd calls this the Y axis)
    Still waiting on the UHMW-PE bearing material for my bearing blocks
    I should have the bearing material here in a couple days
    The bearing blocks have some cardboard in them for this test
    I should be able to crank up the motor speed in Mach3 when I remove the cardboard and have the linear bearings dialed it
    I machined a Nema 17 raised motor mount from G10 and made the idler pulley bearing assembly from scratch
    Under the 9 x 9 bed is a couple GT2 belt clamps that I machined from G10
    I am using a spring to keep tension on the cut belt but I need to get a stronger spring
    Here's a few pics and a movie
    Jul 2007
    189
    I installed the UHMW-PE bearing material in the bearing blocks and got the X and Z axis up and running
    The X axis has a spring under the bed that keeps the belt tensioned
    The Z axis has two shafts with two GT2 pulleys and belts
    The bottom shaft is the drive shaft and the top shaft just free wheels
    I can slide the top shaft up or down to put tension on the belts
    Here's a video of both axis running some G code
    Jul 2007
    189
    Got the Y axis running today.
    Got to tidy up the electronics and then on to the A axis extruder
    Mar 2003
    6855
    Im loven it look great!
    Jul 2007
    189
    Thanks Paul
    The linear bearings are gonna work out great I think
    They are a bit tricky to set up, but not difficult
    You have to shim the backside of the bearing material using .005 inch shims to remove all the play
    There are 3 bearings per bearing block like in this pic
    Jun 2004
    6618
    That is looking very cool.
    Lee
    Jul 2007
    189
    Thanks Lee. It's a ton of work, but fun and challenging
    Jul 2007
    189
    I just ran the Gcode on the new printer for the small cup I made in my extruder test
    My CNC machine took over 1.5 hours to complete the cup
    The new machine did it in 32 minutes and there is still room to crank up the motor speeds in Mach3
    A second run with some dialed in settings in slic3r finished in 25 minutes
    Jul 2007
    189
    I spent a couple days getting everything square, bolting down the electronics and got the A axis extruder almost done.
    Here's a video of the 3D printer running the same cup code I did on my CNC machine extruder test.
    The 3D printer is finishing the same code in 25 minutes that my CNC machine did in 1 hour 40 minutes
    It hard to see just how fast the X and Y axis are in this video but if you lay your hand on the X axis bed, it feels like an intense vibration as it rips the code off in Mach3
    I should have the extruder finished in the next couple days and be ready to print the cup code to compare it to what my CNC machine printed
    Jul 2007
    189
    I have been pecking away at the printer build
    All 4 axis are dialed in and calibrated in mach3
    I built a ball bearing filament spool dispenser at the top of the machine
    I built a glass plate work surface
    I made a bunch of improvements to the extruder
    I added a 40mm fan to the extruder
    I added a touch probe to zero out the work surface
    I am currently adding limit switches.
    I'll take some detailed images once I have everything in place
    Here's a complex shape I printed and a pic of the machine
    Mar 2006
    119
    Hey Doug, great work- subscribed!
    Thanks for sharing the details of your builds.
    Mike
    Expensive tools can be cheaper than professional therapy
    Jul 2007
    189
    Hey Mike,
    I'll try and get some good detailed pics of the build soon
    Jul 2007
    189
    I finally had some time today to take a bunch of detailed pictures of the 3D printer
    I have added several things to the printer since I last posted here
    This page on my web site has lots of pics and info
    My 3D Printer build page
    Check out this twisted cup shape I printed
    http://www.el34world.com/Misc/Cnc/images/IMG_7485.JPG
    Here's an small image of the printer
    Go to the link above to see large detailed images
    Mar 2006
    119
    Wow man, great site- I will definitely soak up all the info. I really like that homegrown extruder too.
    Thanks, Mike
    Jul 2007
    189
    Thanks Mike
  17. #17
    Jul 2007
    189
    After using the 3D printer for a couple weeks, I made some improvements to the extruder.
    The filament tension arm was hard to grab hold of and swing out because the tension spring is very strong
    And so I added a finger indent that makes it easy to swing out and load filament
    I made the tension swing arm a bit fatter at the top so I could use fender washers and get a more stable pivot point
    I added an On-Off switch and a LED indicator
    The switch turns on the 40mm fan and the extruder
    I added an eye bolt at the top to keep the filament aligned with the filament gear and idler bearing
    The fan swings out of the way and uses a wingnut to lock it in place
    The idler bearing is a 5mm sealed bearing with an outer shell added that has a groove machined into it
    Here's a couple pic of the extruder upgrades
  18. #18
    Jul 2007
    189
    I changed out the nozzle on my printer
    The brass acorn nut was dragging material around and there was not enough brass on the end to be able to machine it down to a finer point
    I purchased a makerbot style .4 mm nozzle and the prints are much cleaner now
    I printed this skull in 4 parts and glued them together
    I added some LED's behind the eye sockets just for fun
    The lid comes off just above the eyebrows for access to the electronics
    I added a few pics of some of the prints here
    3D prints page
  19. #19
    May 2006
    2420
    Great work ! I have been trolling through the net looking for info on 3d printing (stupid me looked everywhere except the zone (chair) ) and your build log just made everything a lot clearer.
    Just a couple of things I am still unsure about, what is the extruder clearance from the surface being printed ? Lets say you are using a 0.35mm nozzle (sorry for the metric) do you keep the nozzle the same distance above or is there a rule of thumb to use ?
    Also I was going to do the same thing as you and try it out on my router first then build a dedicated machine that is faster, even though I am building a new router that will pretty much fly...is there a maximum speed for printing or is the sky the limit ?
    I literally have a bucket of servo's lying around and enough electronics to create smoke so I may be better off building a machine from scratch eventually, just want to prove the concept first. Apart from slow printing is there any issue with using the old router for starters ?
    Cheers.
    Russell.
  20. #20
    Jul 2007
    189
    Hi Russ,
    I just touch the extruder tip onto the blue tape surface and set mach3 to zero Z
    When you print an object, you can specify an outer ring to print so many times before it starts the actual print
    You can see if you are laying down the plastic properly or not
    If not, just stop the print, adjust the nozzle up or down, set Z to zero and start again
    It's hard to use a metal touch down like you can on your router because the extruder tip always has some melted plastic on it and so a metal touch plate does not work really well.
    I put a strong light on the bed and adjust Z zero by eye
    You want a tiny gap, maybe .2mm is all
Page 1 of 2 12
  1. Build your own large format printer?
    By rackbox in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-22-2016, 06:25 PM
  2. RapMan 3d Printer Build Video
    By robyward in forum Videos
    Last Post: 12-01-2012, 12:05 PM
  3. custom 3d printer build
    By fritzgutten in forum 3D Printer / 3D Scanner Discussion
    Last Post: 11-27-2012, 08:40 PM
  4. NO PRINTER PORT .HELP for my g0704 build.
    By macatoms in forum Benchtop Machines
    Last Post: 02-17-2011, 10:56 AM
  5. Need to build a printer for glass and plastic
    By originator in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 11-03-2008, 01:22 PM
