587,754 active members*
2,763 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > New product --stepper motor driver IC --THB6064AH
Results 1 to 16 of 16
    Nov 2011
    Smile New product --stepper motor driver IC --THB6064AH
    The THB6064AH is a PWM chopper-type sinusoidal micro-step bipolar stepping motor driver IC.
    It supports 8 kind of excitation modes and forward/reverse mode and is capable of low-vibration, high-performance drive of 2-phase bipolar type stepping motors using only a clock signal.
    Features
    Single-chip bipolar sinusoidal micro-step stepping motor driver
    Uses high withstand voltage BICD process
    Forward and reverse rotation control available
    Selectable phase drive (1/2, 1/8, 1/10, 1/16, 1/20, 1/32, 1/40, 1/64 step)
    Output monitor pins (DOWN / ALERT)
    Equipped with reset and enable pins
    Built-in thermal shutdown(TSD) and over-current detection(ISD) circuit
    Parameter
    High output withstand voltage: VDSS 50 V
    High output current: Iout 4.5 A (peak)
    Packages: HZIP25-P-1.27
    Dementions:3.6*1.4*0.5 cm
    Weight:9.86g
    Website:[url=http://www.hhbytech.com/en/]
    Nov 2011
    Is there anyone give some comments about this product?
    Jul 2008
    199
    Quote Originally Posted by Jerry888 View Post
    Features
    Parameter
    Weight:9.86g
    dear jerry,
    congrats for such a good product. I think you should put some units of it on the ebay. I bet it is going to be a perfect replacement for stk series drivers( i think they are uni-polar). As you said it has built-in thermal and o-current protection, it will be a long life solution for the diy'rs.
    Why don't you make a successfull stepper driver with that and put the complete schematic here. It is going to make a perfect driver for nema 23 size motors.
    jasminder singh
    It is better to die for something than to live for nothing.
    Nov 2011
    Quote Originally Posted by jasminder View Post
    dear jerry,
    jasminder singh
    Dear,
    Thanks for your comments.:cheers:
    THB6064AH offers simple peripheral circuit, more selectable phase excitation, high output current and high driver voltage, as TB6560. Its excellent performance is a quantum leap ahead of TA8435 AND TB6560HQ.Therefore, it is an updated product.
    Attached Thumbnails Attached Thumbnails THB6064AH ENG Schematic diagram.jpg   THB6064AH ENG P1.JPG   THB6064AH  ENG  P3  2.jpg   THB6064AH ceshiban P1.JPG
    Attached Files Attached Files
    Jun 2010
    Schematic has 2 lines free floating - is that incomplete or something?
    Board image is missing internal layers?
    Pretty pls if possible post better resolution / clearer / higher resolution images for these - schematic and board image, thank you very much.
    Nov 2011
    Quote Originally Posted by MGTp93 View Post
    If you can't see clearly ,please find the attachement.
    Nov 2011
    Quote Originally Posted by Carolyn4638 View Post
    Dear,
    What's the meaning?
    Nov 2011
    [QUOTE=MGTp93;1031294]Schematic has 2 lines free floating - is that incomplete or something?
    QUOTE]
    Dear,
    pin1、4 are NC. Pin7 is base of triode.Pin 7 can pull up to VCC or free float.
    You can refer the datasheet of 6n137.
    Nov 2011
    You can find the announcement from the attachement about THB series chip by TOSHIBA Semiconductor Co.Ltd.
    Attached Thumbnails Attached Thumbnails Anoncement about THB series chips by TOSHIBA semiconductor Co.,Ltd.jpg
    Nov 2011
    Hello friends,
    THB6064AH chips are selling on ebay now.
    If you are interested in them,you can visit http://www.ebay.com/itm/230739000441...84.m1555.l2649
    Best regards,
    Jerry
    Nov 2011
    Please find the announcement from TOSHIBA about THB6064AH.
    May 2005
    1397
    Chip, Professional PCB and full kit are available here:
    massmind Stepper Controls
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Oct 2012
    is this still alive?
    is there overcurrent protection? adjustable? i dont see any VR
    Jan 2005
    364
    Yes, but you have to look in the appropriate forums:
    The chip has overcurrent protection and a VR to set the motor current to whatever value you want, not limited to specific currents using jumpers.
    For more detailled info look here:
    http://www.cnczone.com/forums/open_s...ml#post1185851
    May 2005
    1397
    Quote Originally Posted by whitelabs View Post
    Yes, Chip, Professional PCB and full kit are available here:
    The VR is the small blue square on the right side in the picture.
    May 2005
    1397
    Here is a more direct link to the stepper driver kit: THB6064AH Driver Kit
  1. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  2. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  3. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  4. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
