588,166 active members*
4,731 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > New Roller Hold-Down Increases Production Possibilities
Results 1 to 4 of 4
    Nov 2006
    30
    Contact: Roy Valentine
    FOR IMMEDIATE RELEASE
    New Hyde Park, New York — Techno, Inc. is proud to introduce their new Model 60W roller hold-down system which operates with the Techno Premium Class CNC Router models. It features (4) 2” diameter urethane covered steel rollers with automatic roller lift and retracting for optimal pressure hold-down.
    Because the spindle positioning is placed in-between the two sets of rollers, maximum downward force is being applied to the material, thus preventing part slippage. Now two and three sheets of material can be processed. In an industry where time is everything, this system allows an even shorter manufacturing cycle time. The Model 60W roller hold-down system is also designed with a 3” roller clearance, allowing for easy loading and unloading of materials. Both sides of the machine are equipped with adjustable roller-end-of-travel actuators that are designed to activate sensors and signal the rollers to lift before the outer edge of the workpiece. These automated sensors prevent damage to both the roller hold-down system and the machine.
    Additional information is available online at: http://www.techno-isel.com, or call to speak with an Application Engineer at 1-516-328-3970.
    Dec 2006
    Send me the information - Thanks
    Dec 2006
    5
    Wdo3 here is the link to Techno's Roller Hold-Down Page!
    http://www.techno-isel.com/CNC_Routers/Roller_Hold.htm
    Dec 2006
    5
    Wdo3,
    Here is the link for the Techno Roller Hold-Down Page. Hope it helps you!
