Hi Dennis, I don't understand your point. A chip load of 0.001" per rev at 18,000 rpm is only 18 ipm. Do you consider this as an accessive feed rate? At 5,000 rpm it's only 5 ipm. That's on a par with watching grass grow.
With a fine tip a chip load of 0.001" per rev might be a bit high, so to keep the feed rate up you need even higher rpms on the spindle!
I'm not sure what you mean by a feed rate of 100 fpm. Is that feet per minute?
I've never come accross a commercial cnc engraver with a 5,000 max rpm spindle speed.
Maybe I'm missing something!
Phil
![Smile](images/smilies/smile.png)
