Roman Black, the guy who designed the brilliant Linistepper controller has come out with a new design for a higher current, ultra simple, minimal component count, chopper type stepper controller. And of course, we have a very nice kit available, which has to be the simplest, quickest kit for a micro-stepping controller ever.
The SLAm Stepper, based on the Allegro SLA7062M, is a very quick and easy to build, 3 amp 40 volt per phase, chopper, unipolar stepper motor controller. With only 15 components, and a very frendly PCB, you can have your motors spinning quicker with this design than just about any other.
Here is the design:
PCB LAYOUT? We don't have a board layout yet that would be good for hobby / home etching; the board in the kit is double sided with a lot of vias. Hopefully someone will come up with a good version soon which we will be happy to post on the site.
CONTEST! Just to help get that started: The first person who comes up with a workable single sided layout, I'll send a free kit of parts for one SLAm driver (good for a single axis) and a break out board (good for 4 axis) with cables to get you hooked up and running.
Features
- Simple. Easiest to build (and most compact) SLA7062 driver design ever!
- PMinMO.com^ standard^ 2x5 control connector for mix and match with other open source break out boards and drivers.
- 1A to 3A unipolar motor capability
- Mode switches On-board
- Low power "hold" feature in all microstep modes
- Modes:
- Half-step,
- 4th,
- 8th and
- 16th microstepping
(low power hold in any mode)
KIT: The kit includes all the components and a professional double sided PCB with top silkscreen, thru plated holes and lead free construction. (RoHS compliant). You add your power supply, motor, heatsink, and standard step and direction signals from Mach 3, TurboCNC or other CNC software.
- Professional PCB with wide current paths, ground planes, etc...
- Real SLA7062M from Allegro (not a cheap knockoff like some other hobby cnc kits we know... )
- Stainless terminal screwdown connectors.
- Your heatsink mounts easily at the edge (since it's a chopper driver, only a small heatsink is needed)
Quantity breaks available
Like any chopper type of driver, the SLAm is not as smooth as our other, Linistepper, linear driver and you may need to add external, mechanical resonance damping in extreem cases. The SLAm is more powerful, and will run cool, but your motors may get a bit hot, so make sure they have some air.
