587,683 active members*
3,009 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > New spindle drive for my DM4400...
Results 1 to 7 of 7
    Nov 2013
    13
    Question New spindle drive for my DM4400...
    Hi all,
    This is my fist post in this superb forum
    I'm about to convert my DM4400 to Mach3 and therefore need a new spindle drive but i'm not sure what to get. I have been looking at a drive from CNCdrive - motion controls CNCDrive.com type DG4S-16035 which seems to be doing the job. Problem is that I'm a novice with this servo stuff so it would be nice if you guys could point me in the right direction. Is there maybe a better solution?
    Dec 2012
    569
    Re: New spindle drive for my DM4400...
    why are you converting it to mach3
    Nov 2013
    13
    The magic smoke escaped from the servo amplifier so the thing is not working anymore. Seems like a good time to upgrade to a bit more modern system.
    Jul 2010
    172
    I use a Bardac(Sprint) XRi3600/36 in my 4400's.
    They work pretty good.
    Another option would be a Parker 514C/32
    Timothy
    Dyna Mechtronics DM4400, Bridgeport Discovery 300, HAAS VF-0E, HAAS VF-2D
    BobCad 16, 20, 24 and now V25
    Nov 2013
    13
    looks like great drivers but oh my...that was some pricey units...
    Do you know what the armature voltage from the Bardac is running at full spindle speed? Is it more than 115 volts?
    Are you using the original spindle tachometer?
    Jul 2010
    172
    I was lucky. I picked them up off of eBay for 150 each.
    I believe its 180 volts at the armature and 28 volts for the tacho generator.
    Timothy
    Jul 2010
    172
    This might be a more reasonably priced drive...
    Polyspede PRD8 500 Drive PRD8500 5HP 1PHASE | eBay
    Timothy
  1. MISSING AC SPINDLE DRIVE + 3 AXIS SERVO DRIVE
    By Affaq999 in forum Vertical Mill, Lathe Project Log
    Last Post: 02-20-2015, 03:50 AM
  2. DM4400 will not initialize
    By maddog1927 in forum Dyna Mechtronics
    Last Post: 08-23-2011, 12:48 PM
  3. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
  4. Just got a DM4400
    Last Post: 08-24-2010, 02:27 AM
  5. DM4400 problem with turnovers spindle
    By gelos in forum Knee Vertical Mills
    Last Post: 10-24-2008, 08:16 PM
