Hey, I've been watching this forum from the shadows for a long time and finally need to ask for some help. I'm feeling kinds stuck with my own build and could use some outside perspective.
I've built (and now rebuilt/upgraded) a CNC router of my own design, and I've tried to take advantage of information gained from other builds to avoid some common issues.
The basic setup is a steel box tube frame, with an aluminum epoxy filled gantry. A boxed z-axis, servo motor, 3.7kw ATC spindle... etc. All built with quality parts.
Measuring things shows that I now have somewhere in the range of 20 thou deflection in the X and Y direction with a full body shove on the spindle when its extended all the way down.
The Problem:
I've recently upgraded from the standard 2.2kw spindle to a nice 3.7kw ATC unit. Now it seems that its not ridged enough and chatters like crazy... even on softer materials like wood and acrylic with light loads.
I never had any issues with the old spindle. The overall design hasn't changed. I had assumed that the z-axis with the new spindle and more mass would, if anything improve vibration resistance, not make things worse.
Am I missing something here? Maybe my design just sucks. ha
Things I have Checked:
-spindle clamp is tight.
-linear blocks and rails are all tight and new (Hiwin 20mm x 4)
-ball screws are tight and have no measurable backlash.
-the gantry carriage has almost no flex ~1 thou with a good push.
Any advice or things to take a second look at? I'm at a loss and would appreciate any input.
