Advantage of the machine:
1. light weight about 20kg,portable shape
2. fine surface process effective ,fast speed and low noise
3. low power consumer
4. high precision to 0.15mm line
Parameter:
Portable fiber laser marking machine
power Pulsed(20W)
Laser wavelength 1060nm
Repeat frequency 20-80KHz
Marking range 100X100 150X150 200X200(option)
Marking speed ≥7000mm/s
Mini letter 0.15mm
Mini line width 0.015 mm
repeatabilityprecision ±0.002 mm
power 220V/50Hz-60Hz
Whole machine power 400W
Machine size 610mmX400mmX600mm
Machine weight <20kg
Operation version WinXP
Cooling type Inside aircool
File version WINDOWS
Application area:
Electronic components,battery,communite,houseware,packing.ade rtising,automatic parts,precision instrument,medical instrument.
Application material:
Copper,aluminum,steel,iron,gold,silver,plastic
