Parts and materials on order, been messing with the CAD software today, side plates for the gantry...
The top box is the gantry beam, 50x50, the motor sits down the bottom on a plate that swivels on the point shown. It will be spring loaded but restricted so it cannot jump out of the rack and chew it up.
A couple of 75mm gusset plates under the beam on the inside and a rib or two on theorised should stiffen things up a fair bit.
Going with direct drive to start, with the option of adding reduction drives, belt drive, or even ballscrews later on.
