587,380 active members*
3,148 visitors online*
Page 3 of 3 123
Results 41 to 43 of 43
  1. #41
    Mar 2004
    636
    Re: New vacuum table for CNCRP 4896
    Hello everyone. Sorry for not posting for a while. I got busy with money making jobs which is never a bad thing. I did however get some time this afternoon to pretty much finish up the table. I have 3 coats of poly on the edges and have now surfaced the second side of the table. I placed a sheet of melamine 4' x 5' in size on the table and turned on the vacuums. I couldn't move it. I applied a lot of force and it wouldn't budge. Very good sign. Next up is to find some time to actually cut something. Hopefully this weekend.
    Dan
  2. #42
    MarryU Guest
    looks pretty good :rainfro:
  3. #43
    Mar 2004
    636
    Good Morning All,
    I finally took some time to try out the new table and I am happy to say it worked well. I cut a couple of stools for the shop out of some repurposed melamine I had. The material was about 45" x 60", enough to get 2 full stools out of it. I cut the 1st one and remove it from the sheet to test fit everything and once I was happy, I cut eh second one out of the remaining material. The effective material size for the second one was in essence 30 x 45. The smallest part cut was 12 x 12. I cut relative slow. 200 IPM at .26 DOC with a 1/4" compression bit. One of these days I will try it with a 1/2" bit, but I use the 1/4" compression bit for probably 80 percent of my cuts.
    Pictures and videos below.
    Danhttps://youtu.be/3ryZvn8cbOw
Page 3 of 3 123
  1. Vacuum table help. Custom table for small acrylic parts.
    By czwalga in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-09-2014, 03:06 PM
  2. Replies: 19
    Last Post: 12-17-2013, 07:58 PM
  3. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  4. vacuum table
    By dmglass in forum MetalWork Discussion
    Last Post: 11-16-2006, 12:46 PM
  5. Vacuum table
    By balsaman in forum DIY CNC Router Table Machines
    Last Post: 01-05-2004, 03:18 PM
