588,648 active members*
6,378 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > New VF-3YT arriving in 2 weeks
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Jan 2006
    4396
    Quote Originally Posted by Mic6 View Post
    Hey Toby, what's that manifold on the back wall of your machine?
    Not my machine. IBM bought it. The manifold is for a vacuum assembly. The rest is proprietary.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
  2. #22
    Apr 2008
    65
    To have your software updated from 15 to 16 series software does only take 15 minutes if you have enough Flash memory on your processor. The 16 series software requires 16 meg of Flash and some machines with 15 series dont have enough memory (8megs) so it really depends on when Haas switched to the larger processor memory.
  3. #23
    Feb 2008
    14
    2007 TM-2 had to upgrade main board to get more memory. version 16.04 software and i don't like it as well for probing.
  4. #24
    Apr 2009
    29
    t.lewis
    What is your issue about probing?? Maqybe we can help you to settle it...
    Cheers!
  5. #25
    Jan 2006
    4396
    Any word on delivery yet??
    Toby D.
    Schwarzwald
  6. #26
    Feb 2008
    14
    Upgraded software from version 15.? and it was simple to run. with the new version 16.4 you have to create a program , exit VQC into MDI then run program. then if you want to set tool length you have to create new or insert into existing program. then your left with programs on the machine that you have to delete or let build up. in the old software you picked your probeing cycle entered your values and off you went from the VQC screen. It's new and I use to the old way. It may just take time. We upgraded software so we were running the same on our TL-2 (2009)and TM-2(2007) Wish they would come out with a book on new softwear this big.
Page 2 of 2 12
  1. Anodizing parts weeks or months after machining
    By jkujawa in forum Material Machining Solutions
    Last Post: 09-13-2008, 05:40 PM
  2. This weeks quiz question
    By Al_The_Man in forum CNC Machine Related Electronics
    Last Post: 01-13-2008, 02:35 PM
  3. Im Waiting 4 Weeks For A Transformer
    By FLUTE HEAD in forum CNC Machine Related Electronics
    Last Post: 08-25-2004, 08:52 PM
  4. After 2 weeks, and a few switches, I'm Done!
    By musicmkr in forum DIY CNC Router Table Machines
    Last Post: 07-06-2004, 08:29 PM
