603,890 active members*
4,736 visitors online*
Results 1 to 4 of 4
    Sep 2005
    10
    Question Newb question
    I am looking to build a cnc router from jgro's plans. I have some unique needs and am looking for suggestions. I build custome computer cases and would be using it to possibly cut windows in the cases and will deffinatly be using it to etch designs into plexiglass.
    I feel fairly certain that i can follow/build the plans but i am unsure what motors to use stepper/servo. if i should make only a 3 axis or 4.
    Any help that could be provided would be greatly appreciated.
    Chris
    Chris
    Sep 2005
    10
    I will also be using this machine for parts for various rc robotics and vehicles
    Chris
    Mar 2003
    35494
    Quote Originally Posted by csmith0413
    What type of meterials will you be cutting?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2005
    10
    I will be cutting some aluminum, and some mile steel like found on the side of a computer case and also etching plexiglass. beyond this im not sure what else it will be used for. I will also be using it to cut some woods ie balsa. possibably some light carving in cherry.
    Chris
    Chris
