Hello millers,
i've just purchased a 3 axis cnc machine (router), and i'm a little lost in the wild, 'cause i have almost no assistance from the builder, and the user guide is not about my machine exactly.
My goal is to mill electric guitars...
I have seen many videos on guitar cnc milling, but they don't explain all the things, maybe because it's obvious, but for me not that much.
I've got a T slot table, 4 fixtures.
I need to mill wood on both sides of the stock.
Several questions :
About the spoilboard, what do you do? You tie it on the table with the 4 fixtures, and stick the stock on it? With tape and super glue? It's strong enough for the cnc?
About pointing the spindle on the origin, you use a special tool?
What do you do if you have to dismount the spoilboard from the table, to glue something on the stock for instance? How do you find back the origin?
I use Fusion 360 and i've got Mach3 on the machine...
For planning, just planning, do you use mach3 only or do you use the cam software?
That all for now, thanks for your help, and happy milling!!!
