603,942 active members*
4,822 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Newbie here in desperate need of tech support!
    May 2007
    Hello folks. this is my first post.
    Goal: Find a fairly small metal lathe and related hardware/software to produce, design and customize trumpet mouthpieces. That and some helpful guides, literature etc.
    Don't need much size as a mouthpiece is less than four inches long. I have plenty of brass rod stock.
    Thank you for your anticipated support in advance.
    Lee
    Apr 2003
    550
    here is a good place to start..look around the site a lot...
    http://www.dakeng.com
    Good Luck
    garry
    Jun 2004
    487
    Hello and welcome.
    One choice is member JFettig's (Jon) products: http://jfettigmachines.com/ I believe he offers a complete small lathe converted to CNC. For software, you can run Mach which is great and inexpensive. Jon can give you all the details.
    JR
  1. Newbie leadscrew support/bearing question
    By lukaslouw in forum DIY CNC Router Table Machines
    Last Post: 09-17-2016, 04:13 AM
  2. Bridgeport Tech support
    By sharp-shooter in forum Bridgeport / Hardinge Mills
    Last Post: 01-04-2007, 11:10 PM
  3. Desperate times call for desperate measures
    By lilricky2 in forum Mastercam
    Last Post: 06-14-2006, 02:48 PM
  4. To Tech Support
    By Billyboy in forum CamSoft Products
    Last Post: 01-30-2006, 11:24 PM
  5. In Desperate Need
    By Al_The_Man in forum Servo Motors / Drives
    Last Post: 08-02-2005, 06:55 PM
