Hi, wondering if you can help, I am new to CNC machining and Mach3.
I have wired up my CNC machine and started setting it up to run on Mach3.
The problem:
Mach3 will not register the limit switches or the E stop switches and the Stepper Motors will not turn.
If I hit an E stop or push a limit switch, the LED's in Mach3 on the diagnostics page do not light up.
The hardware I am using: (all from CNC4YOU.co.uk)
HG07 break out board
CW5045 Stepper Motor Drivers
60BYGH401-03 stepper motors
Windows XP on a dedicated PC
What I have done to try and get it to work:
Checked all wiring, reinstalled Mach3, checked parallel port driver. The steppers are receiving a voltage, and the limit switches and the
E Stops are on a Normally Closed circuit, which breaks when I push a switch and test it with a multimeter.
I have run driver test= system excellent.
Under Ports and Pins:
Port set up is on port 1, 0x378
Motor outputs for X,Y & Z are set up on what I believe be the correct pins, DirLow Active is enabled
Input signals are set to port 1, each limit switch and E stop has the correct pin number entered, active low is enabled for each.
Can anyone help? It's probably something dead simple but I at a loss to know what to do next.
Many thanks
Joz
