587,773 active members*
3,323 visitors online*
IndustryArena Forum > CAM Software > CamBam > Newbie needing help with a DXF 3D Drawing
Results 1 to 6 of 6
    Jan 2014
    30
    I've got a 3D DXF. file and would like to know how I can movie it around in CamBam so that the tool-path will start in a different area from where it is now. Could any of you tell me if this is possibe?
    Here below is a screenshot of the file opened in CamBam. I need this drawing to be positioned flat and for it to be milled vertically straight from the top. Ignore the holes as thats no big issue to me and will be done a drill-press prior to the shape being milled.
    I basically need it to be milled from the area where the single hole is, straight downwards to create the shape.
    Apr 2007
    663
    Re: Newbie needing help with a DXF 3D Drawing
    Use the CAD program to oriented the object as it needs to be to be machine as planned, then import into CAMBAM is probably best.
    Though in CAMBAM use/try:
    EDIT>TRANSFORM>ROTATE
    [Check rotating with mouse and its buttons too.]
    and
    EDIT>TRANSFORM>ALIGN
    Also: Make sure the object's surface normals are oriented properly.
    Check SNAP TO GRID settings as well.
    Nov 2008
    643
    Try Edit>surface>Plane slice X or what ever. This slices the part and creates an outline that can be converted to gcode, so you can machine it in 2.5D.
    Apr 2007
    663
    Dean is correct about the plane slicing along X, Y, or Z
    These functions obtain polylines from a 3D object by slicing the object along a given axis.
    Plane slices provide a useful way of generating 2D machining operations from 3D models, without having to redraw the models in 2D. For many engineering or prismatic 3D shapes, 2D machining operations can provide much simpler, faster and more accurate operations than the 3D machining operations.
    It is good practice to create a new layer to receive the plane slice polylines, to make the drawing more manageable and so that the polylines may be viewed and manipulated independently of the original 3D surface.
    Suggestion: Practice on a simple shape first though.
    Jan 2014
    30
    Ahhh Thanks a ton for the help guys but I think I'm still a little ways to go. Heres another screenshot below.
    I need the endmill / cutter to start from the hole where theres the blue area and once again this entire shape or drawing is a pocket to be milled into solid aluminum. I have moved it around briefly with your folks help but how do I make it so that the entire drawing is a pocket and that the endmill will start at the hole shown. I'm not too concerned about the other holes as I will eliminate those from the drawing and do them on the drill-press prior to milling.
    Jan 2014
    30
    oh yeah, how and around where within the red and green line would i wanna move it so that it starts at the hole pointed out?
  1. newbie needing help.
    By DeanJ in forum Machinery Manuals / Brochures
    Last Post: 08-21-2013, 12:54 PM
  2. Newbie to gibbscam needing help
    By sintratech in forum Uncategorised CAD Discussion
    Last Post: 01-09-2012, 04:50 PM
  3. Another newbie needing help with software!
    By rnm85 in forum Uncategorised CAM Discussion
    Last Post: 01-07-2012, 03:26 PM
