Hi, gang,
I am just starting to play with CNC goodies, and I have been searching for an affordable beginner machine with which to learn (and use). I'm computer and electronics literate, and I understand CNC from a broad perspective, but I've never actually used a CNC machine (yet). I have considered building one from scratch, buying a kit, or buying a Taig / HF / etc mini mill and converting it to CNC after I've messed around with it manually.
In a few days I will have an opportunity to buy a Sicono SIC-330 desktop router/engraver/??? for about $500. It is reportedly in good condition mechanically and electronically, although the unit's manual control keypad is toast (unobtanium firmware flash required), leaving only CNC control.
It has an 800-W spindle and a noise-reduction enclosure.
The kid (25) selling it is a mechanical engineer with a brand new infant -- and doesn't seem like a CL psycho.
My budget is minimal right now, and every mill I want costs about $10,000 too much. This one is made in China, sells for $3000 to $4000 new and claims to incorporate German-made ball screws. But other than a few YouTube videos, there are no USA parts sources, resources, direct reviews, etc. The seller, who has worked as an engineer and a CNC operator, says the little mill works well with aluminum and brass, is "tight," etc, but is too small for his personal needs and isn't getting used anymore.
I need advice on whether this might be a good deal on a "learning" machine that might also produce usable stuff.
Thanks in advance,
--sohosources
