603,796 active members*
4,581 visitors online*
Results 1 to 5 of 5
    Jun 2017
    3
    newbie Q regarding fanuc 0T lathe Gcode
    Hello,
    I'm studying the excellent book by Smid on gcoding.
    on a lathe When doing an independent (of movement) compensation how does the control know in what direction to move
    to compensate for the tool nose radius comp amount stored in the R column in the machine tool offset table - activated by the last two digits of the T command,
    Since no G41,G42 command is given?
    for instance - N1 G00 T0202.
    please see below snippet from chapter describing lathe offsets:
    I
    Independent Tool Offset
    For an independent offset entry in the program, tool offset
    is applied together with tool indexing:
    N34 G00 T0202
    This command is usually programmed as the first block
    for each tool (in a clear position).
    At this point, the tool is still at its indexing position.When tool
    offset is activated, it will cause a physical motion by the
    amount stored in the offset register.
    page 304 Chapter 34 cnc programming handbook peter smid third edition.
    Thanks in advance for any replies!!
    Feb 2011
    353
    Re: newbie Q regarding fanuc 0T lathe Gcode
    there is a tool tip Orientation that you will need
    in the wear offsets you should see x z r t
    r= radius of tool
    t= tool tip orientation generally this will be 0-9 positions
    this t code will move the tool when cutter comp is called in the direction
    Jun 2017
    3
    Thanks!
    I meant that if I call T0202 for example, since I called the comp by not writing T0200, the turret moves slightly still while located at machine zero.
    as I understand, this tiny jumpy movement is due to moving the tool since R,T were activated.
    But since no movement coupled with G41/G42 was programed, how the controller knows to what side to slightly move the turret, whether to move the insert further to the right of the workpiece or to the left of the workpiece?
    Thanks! and sorry by my newbie misunderstandings..
    Feb 2006
    1792
    When T0202 is commanded, the machine shifts the coordinate system appropriately, to suit tool no. 2.
    This can be done in two ways:
    1. coordinate display remaining same and tool moves
    2. tool does not move and the coordinate display suitably changes.
    Both are equivalent. The selection of method is parameter dependent.
    This has nothing to do with G41/G42.
    Jun 2017
    3
    Quote Originally Posted by sinha_nsit View Post
    Thanks very much! :)
  1. Gcode issues using Artcam with a thermwood machine/newbie
    By mike.anthony in forum Commercial CNC Wood Routers
    Last Post: 09-30-2012, 11:32 PM
  2. Thermwood GCode Problems with Artcam /Newbie
    By mike.anthony in forum ArtCam Pro
    Last Post: 09-29-2012, 03:25 PM
  3. Newbie trying to learn Gcode for 810 G
    By joedesu1 in forum SIEMENS -> GENERAL
    Last Post: 04-10-2010, 10:04 PM
  4. PLease help - gcode newbie
    By scotty1 in forum Uncategorised CAM Discussion
    Last Post: 03-07-2010, 12:03 AM
  5. Newbie Q: (Mach/Gcode/Tormach?) display vars?
    By rc33 in forum Tormach Personal CNC Mill
    Last Post: 11-18-2008, 10:16 PM
