603,968 active members*
2,039 visitors online*
    Mar 2008
    Newbie question
    Having difficulty setting up "steps per unit". Running Mach3 to Taig CNC mill with 20 tpi acme. So according to the Mach 3 instructions:
    Default units set to mm
    1.8 deg steppers
    Xylotex XS-3525/8S-4 set for 1.8 deg
    360 deg / 1.8 = 200 steps per turn
    200 steps per turn times 20 tpi = 4000 steps per inch
    Therefore 4000 / 25.4 = 157.48031 steps per mm
    When I specify a 30mm circle at that setting it creates about a 6mm circle.
    Then changed the steps per unit setting to 1574.48031 thinking maybe it calculated in cm internally and this resulted in about a 36mm circle. Kept taking a percentage off and now it is set at 1270 steps per unit which is close BUT there is no logic or reason to base this setting on other than trial and error so ...
    ..can I not read the Mach 3 instructions
    ..am I incapable of operating my calculator
    ..going senile
    ..all of the above
    Any ideas or assistance greatly appreciated - thanks
    Mar 2003
    35494
    Xylotex default is 8 microsteps, so you should have 20 x 200 x 8 = 32000 steps per inch, divided by 25.4 = 1259.8425
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2008
    Smile
    Plugged the numbers in and it's working perfectly. Thank you very much - you saved me from having to commit myself
  1. Newbie question
    By rayellam in forum PCB milling
    Last Post: 04-17-2008, 02:00 AM
  2. Newbie with a question
    By Karlf in forum DIY CNC Router Table Machines
    Last Post: 02-15-2008, 05:53 PM
  3. newbie question ?
    By colka in forum Stepper Motors / Drives
    Last Post: 08-18-2007, 02:09 PM
  4. Newbie Question
    By Alex Westling in forum Fadal
    Last Post: 12-21-2006, 06:31 PM
  5. newbie question
    By leroy in forum Uncategorised CAM Discussion
    Last Post: 07-03-2004, 05:15 AM
