Hello Everyone,
We are very pleased to announce the release of our latest product Cut3D - Powerful, Quick and Easy 3D Model Machining.
Cut3D is the simplest way to machine 3D models from CAD or Graphics design products such as AutoCAD, Rhino3D, 3D Studio, Silo, Lightwave etc.
Scanned data from laser or touch probe devices such as the MaxNC and ShopBot Digital Probes as well as the vast number of 3D models available off the Internet can also be machined quickly and easily.
Cut3D is incredibly easy to use and includes z level roughing, finishing and cut out toolpath strategies, interactive tab placement plus high quality preview rendering that make the software perfect for cutting 3D models.
Multi-sided Machining - Single, Double and Four Sided machining
You can test Cut3D for yourself by downloading the Fully Functional Trial version and cutting the free 3D evaluation models on your own machine. This version will also open your own 3D models, calculate toolpaths create stunning 3D preview images but does not save toolpaths for these models.
High quality Toolpath simulation
Models can be sliced into machinable pieces
Large / thick models that do not fit under the gantry on your machine or you don't have thick enough material can very easily be 'sliced' into thinner sections. For example, a 24" high model can be sliced into 12 x 2" thick pieces that can then be machined and assembled.
Interactive Tab placement to hold the job in place
Let us know if you have any qestions about the new software.
Tony Mac
Vectric
