Thanks for the kind words!
Last night I setup the base on my 24"x36" surface plate, which is perfectly level. Then I used my 12" Starrett machine level to set the base plate level. There appears to be a problem with the bore in the center of the base plate, as the Bull's-Eye level was way off!
After I removed the little level from the plate, I placed it in the center of the base plate and now the Bulls-Eye level is dead center! The bore is too tight, and it's forcing the level off to one direction, All I can say is my head must of been out of tram![]()
