So our Y axis on the NExus is off by .0025". Called Mazak, got an automated message saying the line is no longer monitored?? Anyone know how to re-set the Y axis 0 position on these controls? Fusion control BTW.
Thanks a bunch.
Thanks a bunch.
Yes, it is a parameter, but be careful the X value will also need to be adjusted.
I think the parameter is M16, alter the Yaxis by the error then home the Y axis. then clock a tool station (if it is further out alter the other way then re home and check again). The Xaxis will have moved alter this (probably half the error) then home it and recheck. Hope this helps.
