Originally Posted by
BrianLWilliams
Earlier today an NH4000 Mill lost all power. Took some time to find the issue but it wound up being coolant that found its way into the mist collectors blower motor which kept tripping the main circuit breaker. The issue I am having now that the mill powers on is it immediately comes up with several alarms:
SV 1067 FSSB: Configuration Error (Soft)
SP 1999 Spindle Control Error
SP 1220 (S) No Spindle Amp
DS 0650 (B) Pole Detection Request
I found that the KM0 contactor is not pulling in and so no voltage is being supplied to the PSM. I believe all these alarms are related and that if I can solve the PSM incoming power issue it will likely correct all four alarms, but I am lost at this point. I am not an electrician and the wiring for the coil to pull in this contactor goes back to a printed circuit board. Any help as to what to check next would be greatly appreciated.
Thanks,
Brian
