603,365 active members*
3,210 visitors online*
    Oct 2012
    NO DRO movement when x is manually jogged
    Hey guys, just setting up mach 3 to control my CandCNC 4x8 precision plasma table.
    everything seems to be going well and I've been following the Candcnc instructions to the "T", but I have a issue. When I got to the manual test of the axis motions I found all of them moved on the table, and all but the x axis showed accurate readings in the DRO's (correct motor tunning) BUT the x-axis shows nothing.
    Basically what happens is, I jog the x-axis either direction and it physically moves, but the DRO on Mach stays on 0.000. The only thing that i see when I jog the x-axis is the a axis DRO (slaved to the y-axis) shows a velocity but no coordinate change?
    I'm confused. help would be great I'm a newbie so I may need the "dumbed down" version of what to do.... just a warning.
    Oct 2012
    uninstalled mach 3, the candcnc screens and drivers and re installed everything.... this time it works? haha got to love computers....
  1. How to change tool Manually?
    By happytriger2000 in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2013, 08:55 PM
  2. X-Axis will only move if jogged
    By gijed in forum Mach Mill
    Last Post: 02-26-2012, 10:24 AM
  3. VM1 Setting zero's manually (no probe)
    By mafitch7479 in forum HURCO
    Last Post: 08-23-2010, 10:48 PM
  4. cnc - is edge finding done manually?
    By Numb Nut in forum Benchtop Machines
    Last Post: 11-09-2008, 10:00 PM
  5. can this be programmed manually?
    By 300sniper in forum G-Code Programing
    Last Post: 02-15-2008, 05:07 AM
