603,919 active members*
2,933 visitors online*
IndustryArena Forum > CAM Software > Surfcam > no line number in comment line in mpos
Results 1 to 6 of 6
    Apr 2009
    46
    i want to be able to not have a line number in front of a comment. But in mpost the comments have to be on a line by itself. I want the rest of the program to have line numbers.
    this is what the code should look like at a tool change
    N50 ;--------------
    * - comments
    N51 ;--------------
    N52 G17 T2 S2500
    CODE SO FAR
    1st tool change
    comments
    i[arcplane] t[tool] s[speed]
    ect
    I want the comment line not to have a line number in front of it.
    anybody done this?
    thanks
    Marcus
    Sep 2004
    264
    Put an exclamation mark enclosed in single quotes '!' at the line where you want to suppress the line number.
    1st tool change
    '!' Comments
    --ch
    Apr 2009
    46
    I tried that. but the comments have to be on a line by itself. it will error out and say cant understand word omments. That was the first thing I tried. I got it to work kinda. I changed the frequency switch to zero, and put a N[block] in every line witch meant defining a line code, but I get empty lines with line numbers in the canned cycles, which is weird.
    thank you though
    cheers Marcus
    Sep 2004
    264
    Yeah you're correct, this does not seem to work with Comments - it does seem to work everywhere else... Maybe you need to contact your dealer... --ch
    Apr 2009
    46
    figured it out with some help From Paul Andrews,
    you format your comment switch like this
    comments !( ) Start and ending comment characters
    this worked.
    cheers
    Marcus
    Sep 2004
    264
    Ah, Mr. Ground Support himself! Cool, glad you got it sorted. --ch
  1. Replies: 3
    Last Post: 04-08-2011, 01:48 AM
  2. Line conditioners for CNC Equipment and poor line conditions
    By WSS in forum Waterjet General Topics
    Last Post: 01-14-2011, 03:07 AM
  3. omit line number
    By asjad in forum Mastercam
    Last Post: 05-10-2007, 12:18 PM
  4. G-code ploter with line number annotated?
    By webcruiser8 in forum G-Code Programing
    Last Post: 09-21-2006, 11:49 AM
  5. Line Number Range Error
    By gar in forum Haas Mills
    Last Post: 05-23-2006, 11:06 PM
