603,830 active members*
4,035 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > no-name 3-Axis Stepper Driver, 60V/5.0A - $147
Results 1 to 15 of 15
    Sep 2009
    10
    Just joined, and am getting into this hobby.
    Needless to say, this is my first post (yeah!!!)
    I found this driver on ebay, and would like some feedback from you all:
    http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
    Seems low priced...albeit a no-name...
    Jan 2007
    146
    Look at where it ships from! Tech support is lousey or doesnot exist. Directions are in translated english. Not a board for a first timer. For $20 more you can buy a gecko 203 which is protected against miswiring. Do you have your steppers already?
    You might consider this if you are looking not to spend alot of money
    http://www.mpja.com/Category/Motors/...0_17452_MS.asp
    Sep 2009
    10
    confused...
    Quote Originally Posted by jschmitt View Post
    Thanks for the reply.
    No, I don't have my motors alreay, but will be buying something in the 300 oz-in range.
    I'm confused about your statement on the Gecko 203 units. They are $147 per axis, and would then require a break-out board... which would amount to over $500... correct? Or am I missing something??
    I agree that the unit on Ebay may have questionable support, and a manual that is not the best, but hey for $147 for a 3-axis system complete with breakout board... and its rated for 5.0 amps...
    Quote Originally Posted by johnnyzigzag View Post
    Hi Sir
    if you will have a 300 oz-in motor, I would suggest you to buy a 4 axis G540 driver with good support,good document and warrenty. If you buy from them you have no warrenty. Let say if you need to return one of the driver, it cost you $30 at least
    Jan 2007
    146
    I Thought the ad was for one axis not three.
    Sep 2009
    10
    Quote Originally Posted by Kelinginc View Post
    Hi Sir
    Yes, but I'd still be ahead in the long run.
    I guess what I'm looking for is feedback on the unit's features, and to hear back from someone that actually has experience on this drive.
    Dec 2005
    14
    I think for that kind of money, you can't go wrong.
    3 drivers 60v 5A plus a breakout board for $150 really is a bargain imho.
    If I was looking for drivers I would deffinately have given it a try
    Sep 2009
    10
    Red face
    Quote Originally Posted by jeroenvw View Post
    I agree, so I placed an order. However, I did go with the more expensive breakout board with output relays and spindle speed control.
    From a feature standpoint, it "seems" to be just as good as anything else out there. But I won't really know unless I am able to play with it and other units for comparison. (not likely to happen since I'm not in the business of buying different models for the sake of comparing)
    From a cost standpoint, even if one driver fails and I have to replace it, I'm still no where near I would be had I gone with the more conventional solutions. (heck, I can replace the whole kit three times over before I start loosing out)
    If I'm wrong in my analysis, I would appreciate feedback. (which is why I started this thread in the first place)
    Oct 2005
    255
    been there done that
    This is one of those things in life that you have to learn first hand.
    I also would have pointed you to the 540's. Mid band control, current control, great support.
    I have also used the "ebay-imports". The decision for me is now a no brainer. GECKO is the way to go for your first stepper machine. Its way simple to setup and use. Has some motor size limitations, but is plug and play (almost)
    So it comes down to how much time is wasted on getting things working and waiting for support (that you can understand)
    Good luck and keep us posted on you progress
    Paul
    Sep 2009
    10
    Smile up and running
    Hi Guys,
    Just thought I'd let you know that my machine is up and running with the kit I ordered from Ebay. So I thought I'd provide some feedback.
    Again, being a newbie, I don't have much to compare this kit to. However, it was simple to get going. There was a motor wiring mistake on the drawings that prevented them from running. I managed to troubleshoot it and reverse the leads and get it going.
    Also, had some trouble in determining the steps per setting for Mach3. I used the correct formula (tpi, microstepping setting, steps per rev, blah blah blah) but it still wasn't calibrated correctly. I ended up using the auto calibration feature in Mach to get it right. So I suspect the microstepping settings on the drivers aren't what they are supposed to be, or my motors aren't 200 steps per rev.
    Regardless, I'm happy with the results so far.
    In fact, I've got my eyes on a fourth driver for turning ...
    Oct 2005
    255
    Congrats
    Woohoo we have a mover. Send some pics if time permits.
    Paul
    Hi Guys,
    May 2005
    1397
    Hey Johnny, congrats on the movement! That ebay listing is gone, but I was wondering if you have any way of finding that driver again. Was there a part number? mfgr name? anything? Do you have a record of the ebay seller ID?
    Sep 2005
    12
    Hardware: the part of the computer that can be kicked. If you can only curse at it, it's software.
    Sep 2009
    10
    ebay listing info
    yup, freeman is right...
    the seller is jarod19810127
    Note that the original listing I found had a simpler breakout board (BOB). I opted to go with the more expensive BOB one that had additional features including onboard mechanical relays for pump/mist control.
    So far, so good. I'm running them with a 5 amp 60 VDC power supply I found off ebay as well. I'll have to get around to post some pics....
    James Newton: if you do end up getting this kit, please let me know if you have similar issues regarding setting up the steps per.
    Sep 2009
    10
    manufacturer of no-name drivers...
    Hey guys,
    I found the manufacturer's website on the drivers I have:
    http://www.cw-motor.com/en/ProductShow.asp?ArticleID=11
    Can anyone tell me what the purpose of dip switches 5 & 7??
    SW5 : 1=Twin-impulse ; 0=One-impulse
    SW7 : 1=Total Flow,0=Semi-flow ;
    What does this mean??
  1. dual axis 16f628a stepper driver
    By yaycnc in forum PIC Programing / Design
    Last Post: 10-30-2011, 09:56 PM
  2. 5 axis TA8435 stepper driver board-confused
    By tiffyted in forum Stepper Motors / Drives
    Last Post: 09-18-2010, 12:36 AM
  3. Stepper motor for 5 Axis TA8435H Driver Board
    By alese in forum Stepper Motors / Drives
    Last Post: 10-15-2009, 05:14 AM
  4. Mechatronics 3 Axis Stepper Motor Driver
    By Chaka in forum LinuxCNC (formerly EMC2)
    Last Post: 02-10-2009, 08:21 PM
  5. 3 axis stepper motor driver using a single PIC
    By david90 in forum PIC Programing / Design
    Last Post: 04-06-2008, 03:22 AM
