603,980 active members*
2,543 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > no plunge feed rate when Z level finishing and Advanced Z level finishing V27
    May 2014
    18
    Hi all,
    I've come across a rather strange problem.
    As I post the code for a Z level finish with multiple depth steps the program doesn't post the plunge feed rate when moving down from 1 depth to the next (it does so for the first step).
    When I select retract for following it does post it, but when I select direct in the following, it plunges with the feed moving speed instead of plunging feed rate.
    Even worse, if there is a G00 to move from an area to the next it plunges with G00 feed, and thats more then any tool can handle.
    I tried setting the feeds NOT to modal (in the PP), but that generates so many codes, to much for me.
    Am I missing something here, or is this something others have come across and maybe found a solution for?
    Thanks,
    Bart
    Re: no plunge feed rate when Z level finishing and Advanced Z level finishing V27
    Sorry, failure to read carefully and engage brain first!
  1. Replies: 0
    Last Post: 02-26-2016, 06:53 PM
  2. feed rate and plunge rate help required please
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 12-07-2015, 09:30 AM
  3. Advanced Z Level Finish
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-30-2015, 11:49 PM
  4. Z Level finishing minimum for finish
    By TPPJR in forum OneCNC
    Last Post: 02-16-2006, 06:01 AM
  5. Replies: 13
    Last Post: 01-10-2006, 03:22 PM
