Originally Posted by
Scott Ashton
I also have this exact problem, stopped working between cuts. I have checked all wiring, tube, water supply, door sensor etc. Light, air pump, laser head working fine but laser will not fire.
Did you unplug the data cable to the power supply and try a test to see if it works? Have you tried to check the power supply incase this has failed? I believe you can also check the voltages into the power supply with a multimeter to check if the data controller is not faulty. You can also use a multimeter to test milliamps sent to the laser tube but I havent got that far yet.
Please keep us updated with this issue so I can troubleshoot my issue.
Scott
