603,416 active members*
2,137 visitors online*
    Aug 2007
    27
    No Power Help
    Hi,I have a desktop router, i was engraving,when the spindle stopped.I reset the machine it started for a few mins,then cut out again with E.009 on the LED display.
    Now it will not power up at all,but when the run button is pressed a small light shows it is running,but nothing.
    On the inverter it has 100H-1.5K.
    Could the trouble be in that.
    Mike
    Jun 2007
    71
    Mike, Check if the ground wire came loose.
  1. power up
    By tonykat in forum Controller Cards
    Last Post: 01-03-2008, 11:48 PM
  2. Power one Power Supply
    By teamtexas in forum CNC Machine Related Electronics
    Last Post: 10-13-2007, 11:05 PM
  3. power for fan
    By dpilott in forum CNC Machine Related Electronics
    Last Post: 07-24-2007, 04:34 PM
  4. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
